Question about Garden
I have a Chamberlain Electrolift Executive G5446 and trying to figure out how & what to adjust. When the door is up, it slants downward. When it rains you have to physically lift on the door in order for it to open. So, do I adjust the bars that are part of the spring hinge assembly, the drive chain, etc. I was searching for a manual, but noluck so far, so thought I give this a try. Thanks for any advice. John
  • 22 Answers
SOURCE: Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Posted on Dec 13, 2008
Pacific Pro
  • 8 Answers
SOURCE: replaced sprocket and worm gear on chamberlain 1/2 opener
The easiest way to fix this would be to take the chain off the sproket with the door and the trolley in the down position. Next hit the wall button and pay attn. to weather the gear is turning clockwise, you want it to turn that direction, wait until the unit stops by itself, next put the chain back on and now you should be able to adjust the limits. otherwise you should call a local professional. They will usually service your door as well as fix your opener.
Posted on Feb 27, 2009
ltfrc
  • 227 Answers
SOURCE: New Craftsman 95320 1/2 hp chain drive only opens door ~6"
Try this link
http://www.garagedooropeners.us/helpgifs/chamberlain_troubleshooting.html
Posted on May 25, 2009
projdoc
  • 2237 Answers
SOURCE: premature flap closure on Kohler actuator chain lift
there may be water in the bulb on the flapper. there needs to be only water so it floats while there is water in the tank. if the air is leaking out, the flapper won't float. it might be best to replace the flapper. it's only a few dollars at home depot or lowe's.
Posted on Aug 28, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
Replaced a garage door opener (motor only) will only go downward a foot then back to the up position...tried the force button and the spring adjustment. why wont it work
Try this.
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Oct 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Remote for electrolift modelno g5446 busted what to do?
Time for a new opener. That opener you have is very old and parts are no longer available.
Oct 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Lights for door opener do not come on when door is opened or closed. Where do I find switch that controls this. The wall-mounted control does not appear to function. It is a Liftmaster professional...
I have an Electro Lift model #G5446. The light switch in the opener has a break in the hair-like wire wrapping the activator arm. Thus my light doesn't work. I crazy glued the wire and it worked about 10 times, but quit again. I'm afraid that heat affected it. It only takes loosening 3 screws to remove it, and it seems to be an easy replacement---why can't I find the part???
Nov 29, 2010 | Chamberlain 12HP Power Drive Chain Drive...
I have a Chamberlain garage door opener - Electrolift Executive with command control model #5446. I need to program the remotes but do not have a manual. The remotes have dip switches inside that I can set...
THERE SHOULD BE A SQUARE BUTTON NEAR THE ANTENNA WIRE THAT IS THE LEARN BUTTON. IF THERE IS NO SQUARE BUTTON THEN THER SHOULD BE A ROW OF SWITCHES ALSO NEAR TH ANTENNA WIRE
HOPE THIS HELPS
Mar 07, 2010 | liftmaster Chamberlain Garage Door Opener...
The door no longer closes correctly leaving a gap at the top. When open it is no longer horizontal but falls to a downward slant
It sounds to me that the oven door hinges need to be replaced, especially if it is a drop down door
They need replacing as a pair.
There is no povision made for adjustment on hinges.
Hope this helps you.
Dec 08, 2009 | Miele H340-2 BP Pyrolytic Electric Single...
Door wont close all the way
Try adjusting the down force, Turn screw an eight of an inch.
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Picture Slant
You will have to adjust the yoke transformers on the necks of the color guns. this should clear up the slanted picture.
Sep 24, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
