Question about GE Profile WPRE6100G Top Load Washer
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will not start normally or fill with water, goes rite to agitating then when goes to drain and spin, will not spin and shuts off,
    Sergeant:
  • 170 Answers
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Posted on Mar 21, 2011
Washer wont spin or agitate and when set to drain and spin immediately starts making a noise and doing nothing with lid closed or open. what could it be?
Sounds like a load out of balance. Try shifting the clothes then press the spin cycle. Sometimes unplugging the washer for a minute or two resets the timer. Are you over-loading with heavy items?
Feb 08, 2015 | Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Can't stop cycle
You probably have some other issue with the machine if it won't stop, but the machine may also not be spinning the mat out because the load is unbalanced. If you put it in on spin only, watch to see if it actually spins up to speed or not. You will see it rotate the drum back and forth a couple of times - it is sensing the weight of the load and trying to balance it. I the machine can't balance it, it will never spin up to max speed. If this happens, put a few other items in the washer with the heavy item (they need to be of similar weight - like some towels or a heavy jacket or something) and try again. Good Luck
Apr 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer quit working in middle of cycle, won't even come on
Look under the washer. Is there a little pile of black rubber shavings? With the heavy load, you may have broken the basket coupler between the motor and the drum. Try turning off the selector, and move it one click at a time towards the end of the cycle and turning back on. Hopefully it will drain for you. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum.s-l225.jpgs-l225.jpg I attached pictures of a couple types. This part is a common problem when you put a heavy load in, because the rubber takes more stress.
Jul 09, 2017 | Frigidaire Affinity ATF7000E Front Load...
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
My whirlpool duet washer spins but cloths still damp after full cycle stop.
I have the same washer and it will do this if I have put a load of clothing that is not even in weight for example I washed sheets with a heavy blanket and I then had to run the Drain Spin cycle. Hope this help
Sep 06, 2009 | Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
My spin cycle
does the washer have paddles on the inside of the drum if it doesnt then try putting alittle less clothing if there is too much clothing then the items tenned to get pushed together and tangle themselves up which means together they are to heavy to spin
Aug 19, 2007 | Crosley CW6000 Front Load Washer
GE Profile WPRE6100G Top Load Washer Logo
215 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
