Question about Brother InnovIs QC1000 Electronic Sewing Machine
I get skipped stitches when I use my decorative stitch #27 and ZigZag stitch sewing heavy layers of fabric. I have changed my needle, cleaned out the machine and sew very slowly; basically I have done everything that the manual has told me to do. I have taken it to my dealer and he has adjusted the needle bar and checked the timing. It is only when I am going thru layers of material to make pot pinchers and oven mitts. The straight stitch is fine. Any suggestions?
  • ecohen276 Mar 22, 2011
    HI
    Thank you. Last night I tried a 16 needle and it worked like a charm. I was getting quite frustrated and now today I am going to buy a stash of 16 needles!
  • 415 Answers
Did you use a larger sized needle for the think fabric? It sounds like the needle isn't penitrating deep enough. You will need a larger needle size for the thick fabric and you might try slightly adjusting the tension tho a larger needle may be all you need. Make sure it is a sharp not a ballpt needle too (assuming you're not using polyester knits which isn't something one usually makes oven mitts with :) )
Posted on Mar 21, 2011
Testimonial: "Very pleased!!!!!!"
  • ecohen276 Mar 21, 2011
    Thank you. I am using a sharp microtex size 14 needle. Both patterns are Vanilla House so I assumed that it is for home sewing and my machine. Please give me some more suggestions as I am quite frustrated and upset.
    Thank you again
  • mszona Mar 22, 2011
    Since you've had the machine checked out and since you are sewing through thick layers I would try a size 16 sharp needle and see if that works. Typically you use the large needles when sewing thick fabrics like blue jeans, canvas etc. but as you are sewing through multiple layers it may just be that it is too thick for the needle though i would have expected the needle to break if it was too small. The symptoms sound like the needle isn't penitrating into the plate deep enough to form the stitch. Most to the time I avoid decorative stitches through very thick fabrics, zig zag stitch should work tho.
    Try taking some scraps layered at the thickness you're trying to sew through. Start with a large zig zag stitch, both longer and widest and then adjust both down and see if it still catches and forms the stitch properly. You can also adust the pressure on the feed dog (if that machine has an adjustment, not all machines do) and see. I would make adjustments until you get a good even zig zag stitch at a shorter, narrower stitch before trying any decorative stitches as they are more difficult to notice where the problem is.
    If the stitch is loopey on top the bobbin tension may be too loose. If the stitch on top is pulling thru to the bottom side then the bobbin is too tight. This is why you want to trying sewing through the same thickness with a broad zig zag to check the stitch first.
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Thread doesn't catch when sewing heavy fabrics with White ESP sewing machine.
make sure the needle , thread, fabric are compatable with each other
the tension must be adjusted also
Mar 29, 2012 | Sewing Machines
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
Skipping stitches and knotting up underneath.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
Stitches are skipping, bobbin problem?
Here are a few things to try. One of these should fix your problem.
* Re-thread your needle
It may be threaded incorrectly (backwards).
Your needle may be blunt, bent, or otherwise damaged.
fabrics and a sharp needle for wovens (or a universal needle for either).
It may be too light for your fabric.
* Change your thread
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure. I know you said you checked this already but it might not hurt to double check it.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with
stitches.
Hope this helps.
Sep 15, 2009 | Kenmore Sewing Machines
Whenever I zig zag my machine skips stitches.
Try these solutions.
*Change your needle
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
stitches.
I hope this helps you.
Sep 15, 2009 | Bernina Activa 130
Brother InnovIs QC1000 Electronic Sewing Machine Logo
186 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
