Question about Magic Chef Toaster Ovens
The oven turns on and works fine but I'm unable to turn it off. i have to go flip the breaker to turn it off. The clock does not appear to be right up against the screen, at times temp/clock fades in and out when the door closes or gets bumped. I don't know what to do please help! Is it worth getting a new stove or is the repair simple or will it cost the price of a new stove?
    Sergeant:
    Champion:
  • 422 Answers
If your unit is already old enough, I think it will need to replace many parts. So it is worth buying a new one than to repair it because many parts will be replaced soon. I hope I give you some idea.
Posted on Mar 21, 2011
Euro pro to241r
follow this steps and fix it. God bless you
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Oct 10, 2013 | Toaster Ovens
Tip
How I Fixed A Break
My TLWTOB6 Salton Toastmaster Lightwave broke, and I fixed it. It had still turned on the display OK and pretended to run, but neither the top nor the bottom lamps would turn on. Also, it made no clunk sound that it would usually do when turning on the lamps.
I took it apart (keep careful track of which screws go where, and there are lots of sliding tabs to put pieces together). I examined the bottom of the circuit board holding the big electronics, and saw discoloration; evidence of heat damage. I wiggled a wire near by, and its quick connect tab came off the circuit board; it hadn't been soldered right at the factory. So, I resoldered it (hope my job was done better), and put it all back together, breaking and resoldering a data cable in the process -_-
So, it works fine now, and hopefully will last a while. By the way, the web address in the manual, www.toastmaster.com, doesn't work any more, and the URL is not associated with any IP address right now. Also, there appears to be no fuse inside the toaster oven.
on Aug 17, 2010 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Black & Decker toaster oven won't work
We've had many of these over the years...they seem to run along just fine, and then, one day, they quit. There is no fuse, but if it's the only thing plugged into that wall outlet, the one thing you might check is the circuit breaker on that line. To be sure, plug a lamp into the socket just to make sure you're getting electricity out of the wall.
Sorry to say, it may be time to purchase a new unit.
Sep 14, 2017 | Applica CTO6301 Toaster Oven
The Breville BOV650XL will not power on.
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
My TRO651 Toaster-R-Oven does not work on any function and the blue light does not come on. I removed the right side cover and checked all the connections, then I cleaned the two sets of contacts with fine...
May not be too hard to fix. On the thermostat, you will see 5 wires coming from it. black and white on top (leave those alone), and on the bottom of the switch, there are red white and blue wires.
The white wire with the burnt connector(from use) is the problem. I had that switch apart, seen how it works. The 3 wires at the bottom (red, white, blue) is like a spst center off switch with white being the common center wire. Red is for oven, and blue is for toaster. After I rebuilt the switch the first time, and it happened again, I just bypassed switch by connecting that burnt bottom white connector, to the red timer wire connector. Oven will work, toaster will not. The oven turns off when timer runs out. Can also unplug or turn down thermostat all the way so it does not use much power when done using till timer runs out. If you have a spst(center off) switch, you can mount that too to the side panel if you find one rated for it. Just make sure the bottom white wire is used as the common center wire.
B&D will not sell that switch that is broken. I tried that before I took that switch apart. Glad I did take it apart as I am sure their new switch would have failed quickly as well.
Aug 02, 2011 | Black & Decker TRO651 Toast-R-Oven Toaster...
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
Farberware Convection Oven T490c does not turn on.
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
Nov 28, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Oven does not turn on
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Jan 23, 2008 | Black & Decker CTO6300 Toaster Oven with...
Toaster Ovens Logo
93 people viewed this question
Top Magic Chef Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Are you a Magic Chef Toaster Oven Expert? Answer questions, earn points and help others
