Question about Viking Dishwashers
My dishes don't dry in our new Viking dishwasher.
  • Viking Master
  • 3,247 Answers
It might be helpful if you provide the model number.
For proper drying of dishes you need to make sure the Rinse aid is set at the right level plus the drying fan is working.
Some dishwashers also use the hot air by running the heater. If the heater is not working then drying can be affected.
Also might help to read this post.
Posted on Mar 21, 2011
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
Kenmore dishwasher leaving a lot of water on door, bottom, wall and dishes! it STINKS!
The pump could be leaking. The drain could be plugged - hence the smell. Taking a look underneath could reveal what needs to be fixed. I don't have an answer for why dishes are still wet even after a hot wash and heated dry but perhaps it is related to the other problem
Oct 22, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
Is there anyway to only dry the dishes? Sometimes the dishes don't get all the way dry and I just want to run the dry cycle again. Thanks! Dawn
You could simply open the door at the end of the cycle and let the air do the job. If your dishwasher is controlled by a manual dial, you could open the door, move the timer past the wash cycles stopping on the dry cycle and close the door to start another dry cycle. This option is expensive, by the way.
Thanks for your question @ FixYa.com
Sep 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Viking dishwasher leaves a white residue on the dishes. How can this be fixed?
RUN CITRIC ACID THROUGH A CYCLE WITH NO SOAP AND ALL AFFECTED DISHES
Jan 07, 2011 | Viking Dishwashers
Dishes not drying properly
You may have it set to an ECO wash (economy)witch may exclude drying cycle at the end to save power.
May 28, 2010 | Viking DFUD042 Built-in Dishwasher
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher leaves a film on the dishes
I've been reading up on this because my dishwasher has done the same thing. I'm not so sure it's the actual machine, but the kind of water that is used in your city. I have read that the water temp. should be between 120 & 145 and that you should put vinegar in the jet dry container. I'm going to try this with the highest of hopes because who wants to wash their dishes TWICE? :(
Nov 15, 2007 | Viking 24 in. Professional Series VUD040...
Dishwashers Logo
408 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
