Question about Speed Queen AWS51NW Top Load Washer
Speed Queen AWS51NW Top load Washer. Fills with water and once lid is closed machine will not agitate but makes a humming noise. If you move the dial to rinse it will at times rinse out the water.
  • scarl100 Mar 21, 2011
    Where's the control board located?
    We hope it's the fix! Thanks for your quick respose.
    Genius:
  • 1,114 Answers
You will need to replace the cycle timer, or control board to resolve this issue.
Posted on Mar 21, 2011
  • Charles Huckeba
    Charles Huckeba Mar 21, 2011
    This part is located behind the panel that you use to select the washer functions. It controls the entire washer.
  • Charles Huckeba
    You are welcome!
Speed queen washing machine fills water but does not agitate but all other cycles spin and rinse working perfect. i took out the belt and started the cycle and the motor was moving fine.
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
Nov 10, 2015 | Speed Queen AWS44NW Top Load Washer
Smell coming from AWN32 speed queen top loading washer
All washing machine "smell" when the lid is left closed for more than one day. If it is really bad it might be something inside the body of the machine or something caught under the agitator.
Inside the body work. Unscrew the three screws at the bottom of the front panel. Lift the bottom of the panel forward and up. Remove. Make sure the machine is unplugged and switched off before reaching into the body work. Look for something "smelly"
Agitator - switch off and unplug - depending on the model unscrew the top cap on the agitator. Some models do not have an screw cap although it might look so. Reach with both hands into the machine and grab the agitator at it bottom flanges hands opposite each other. Pull up hard - it does not let go easily- make sure it doesn't have a top screw cap. To replace just push back until it clicks or replace and tighten the top cap.
Dec 13, 2013 | Speed Queen Washer Top Load AWN432
I bought a new Speed Queen AWN432. Installed it, filled it with water. When the water stopped filling the motor does not run.I've pushed the lid switch on the back side to make sure it was close
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
Jan 29, 2012 | Speed Queen AWN432 Washer
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
Washer fills up but the will not wash
sounds like something is clogged in your pump under the washer.
see the motor drives the pump, but if it is clogged, the motor will not turn.
Sep 12, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Washer does not agitate
Push down on lid to activate door switch.
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Speed Queen AWS51NW Top Load Washer Logo
239 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
