Question about LG Washing Machines
When spinning the bowl seems to go off balance and bangs against the sides. The machine sits level and it does it even if it the bowl is empty.
I have just bought an LG washing machine it did this once when I had a heavy duna cover in, and I opened lid and adjusted the load and it hasnt done it again. Now when I load the machine and have a big load I position them evenly around. I hope this helps you!
Posted on Mar 21, 2011
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
My fisher and paykel eco washer spins weirdly and makes lots of noises
Noisy
If the user is complaining about noise, it may be in a number of different areas. Is the noise during
spin? Is it a banging sound? This would typically be the drain hose, inlet hoses, mains lead or
harness. If it is an out of balance noise, check that the machine is level and stable. Check the
bias spring and balance rings. Remove the inner bowl and check that its weight is within
specification (Refer Section 1.12).
If it is a 'clunk' that occurs up to 3 times per cycle, this would be a bowl check and is completely
normal. It occurs when SmartDrive is draining and 3/4 empty. This is a 'feature' and a noise that
cannot be reduced.
Other things to check are:
• Is SmartDrive level and on all four feet equally.
• Check the mains lead, inlet hoses and drain hose outside the wrapper, behind SmartDrive.
• Check the harness and drain hose inside is not banging on the wrapper during spin.
• Check the bias spring is fitted correctly.
• Check the 2 balance rings in the inner bowl contain water. Check the bowl weight.
• Check for noisy suspension rods.
Apr 04, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing machine is off balance
Not fixed but it still goes so I guess i'll just keep using it till it breaks down altogether
Nov 08, 2009 | Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Hotpoint Aquarius WF250 Loud banging when spinning
The hardest amount to balance is a load with just one item.Because you have nothing to counter balance the other side.So,first off,put in a normal load ,make sure your washer is level by using a level to assure it is, other wise if its not all the clothes will group in one spot where its not level ,than when time to spin you have a un balanced load.
May 21, 2008 | Washing Machines
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
50 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
