Question about Lochinvar ENERGY RITE 399000 BTU PROPANE GAS POOL HEATER
I have a Lochinvar pool heater that on the dispaly is showing Air Pressure Switch Open. I looked at the manual and it talks about air flow from the supply vent and exhaust vent. Than it says about combustion chamber prassure. Is this a common problem or do i possibly have a defective Pressure Switch
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Try this before taking anything apart to far:
The pressure switch is located in the front header, behind the
upper side jacket panel, above the water connections. When
required, the pressure switch can be reset with the following
procedure:
1. Clean filter and skimmer.
2. Start filter pump.
3. Set digital thermostat to highest setting.
4. Turn the adjustment knob on the pressure switch clockwise
until the combustion air fan in the front control panel turns
off. Fan will not turn off if system pressure exceeds 5 PSI.
5. Slowly turn the adjustment knob counter-clockwise until the
combustion air fan turns on. Turn knob an additional ¼ turn
counter-clockwise.
6. Turn filter pump off and on several times. The heater should
shut down immediately when the pump stops.
7. If the heater does not shut down immediately as the filter
pump stops, repeat steps 4, 5 and 6 until proper operation
is achieved.
8. Reset thermostat to desired temperature setting.
If after doing all of the above you still have the problem.... you can remove the switch and check for debris in the water passages. If you find debris remove it, reinstall the switch and repeat steps above.
- Still have the problem... Replace the switch.
Thanks for choosing FixYa,
Kelly
Posted on Mar 21, 2011
Air flow rs message?
air pressure switch isnt closing. either problem with air switch, not enough pressure being generated by blower, or air restriction within venting
Mar 11, 2014 | Jandy Pool & Spa
Boiler won't reset error message is air pressure sw
Check the induced draft pressure switch's tubing that connects it to the induced drat assembly, the barbed port that the tubing connects to gets clogged requiring reaming annually or this will happen, if this does not work replace the switch, make sure to clear the port.
Dec 07, 2013 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
Boiler will not reset
Dec 07, 2013 | Lochinvar Energyrite Residential Heaters...
Air energy electric pool heater shows low pressure, low temperature and will not turn on
low pressure will either be gas or water. technician with a manometer can check gas inlet and manifold pressure. ensure adequate water flow from pump. pressure switches generally close at 2psi. you can jump the pressure switch if you think its faulty, or use ohm meter and check continuity of pressure switch
Oct 03, 2013 | Pentair MAXITHERM 333K BTU PROPANE GAS...
Heater has power but flashes code L.P
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect
against certain conditions that could be detrimental to compressor life. The switch turns the heat
pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow
blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Dec 09, 2010 | Hayward Pool & Spa
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Air Switch Lock out open
Check that the lower compartment is sealed, when the screws are out the air switch will show open
Apr 18, 2010 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
Air switch open error code, can't get ignition.
hI blow dow tube s of presure switch might be blocked , jump out pressure switch see if it lights if so new presure switch
Feb 17, 2010 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
Lochinvar ENERGY RITE 399000 BTU PROPANE GAS POOL HEATER Logo
632 people viewed this question
Top Lochinvar Pool & Spa Experts
Paul Carew
rogerpaul3
Level 1 Expert
David Spradling
David Spradling
Are you a Lochinvar Pool and Spa Expert? Answer questions, earn points and help others
