Question about Slide Remote Operator Dkl400uy 2011
What are the dip switch setting for a dkl400uy gate opener
Mostly be all off unless your setting timing. I found the manual dip3's and how they are labeled on the pcb are backwards.
Manual PCB
1 3
2 2
3 1
that may help you. You can find a manual on internet. There seems to be two versions so you must match the board layout diagram to the one you have in your slide gate.
tim
Posted on Jun 17, 2011
Craftsman door opener key pad lost code. Resetting code does not work. What to do next
Most garage door openers have dip switches for the code set. Open the the access panel on the back of the remote and look inside to see if there are a series of small sliding switches with 0 or 1 on either side.. Should be like 6 of them and very tiny. That is your code and that means you have dip switches. This means that if you get another remote you set the dips in the same sequence.. On the motor there will be another access panel with the same set of dip switches. As long as they match they will communicate. As far as the outside control box you would need to look up the manufacture case set manual. These boxes are an on off switch that opens a circuit digitally and opens the door.
Apr 20, 2018 | Building Materials
Gate will not close manually but will open
This is such a low information and general question I doubt my answer will be accurate but if we assume you mean it won't open using a remote but will open by pushing the button on the operator board, we can then assume you have an issue with either the transmitter or the receiver. The transmitter, also known as a remote or clicker, may have a dead battery or if it uses dip switches, someone changed them. It could also simply have gone bad.
If you have a receiver with a learn button, you may need to reprogram the transmitter. You will need to find out what kind of receiver you have first, then follow the instructions on it to reprogram the remote.
You can find the receiver by looking for the antenna. Follow this to a box, usually about the size of two packs of cigarettes.
Look on the back for a model name and number and do a search for the manual. If it is a dip switch type, make sure the dip switches on the transmitter and the receiver are in the exact same position.
You might want to follow up your original post with pictures of the receiver and transmitter. This will help determine the next step.
Nov 02, 2015 | liftmaster SL3000UL1HP3 1 HP High Traffic...
I close the gate in the morning but find it open when I return home from work in the evening. This does not happen at night and it does not happen every day.Last week it happened on 3 consecutive dys
Change the codes. There are usually dip switches in the remote and gate that can be switched. If it still happens, start looking at the receiver at the gate.
May 30, 2015 | Cars & Trucks
Tail Gate open warning light will not turn off. where is the button switch on the tail gate?
Check with a multi-meter that the switch itself has a open/closed function(ohm meter setting)Hope this helps....
Feb 06, 2015 | 2005 Hyundai Getz 1.3
Slave will not open with Master.
switch leads for master and slave to see if its a wiring issue. if the same gate fails to operate, it may not be your controller.
Jul 05, 2014 | Eagle 100 DC 1/2HP Swing Gate Operator w /...
My electric driveway gates open and close but not completely. The power switches off before they close or open fully
sorry but we have no way of knowing what your control box is set for . try a local repair shop
Jan 10, 2018 | Cars & Trucks
Is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Its kinda hard but if you follow the info in the owners manual for your truck it works. It is not rolling code like a gargae door this is a dip switch on or off .
Jun 07, 2012 | GTO Mighty Mule Automatic Gate Opener For...
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
Have lost a ditec re mote for electric gates ,how do i change the one i have so the lost one becomes un useable
there is a dip switch setting in a box that is connected inside your gate opener just change the up down position and make sure to set your new remote the same.
Jan 13, 2010 | Directed 434MHZ Remote Control
Slide Remote Operator Dkl400uy 2011 Logo
247 people viewed this question
Top Slide Home Security Experts
Lawrence Oravetz
Are you a Slide Home Security Expert? Answer questions, earn points and help others
