Question about Pioneer TS-TRX50 Car Speaker
How are the wires colored for positive and negitive on these speakers both have clear insulation on them or does it matter since this is a coil ? what impedance should i get ohms reading when i check ?
    Sniper:
  • 108 Answers
There is no difference u can connect any any way .as it is a speaker it dosnt have polaritys
Posted on Mar 22, 2011
Rear door speakers wiring diagram
Left rear speaker driver side color is Black/Yellow positive and Black/Orange is negative. Right rear speaker passenger side Black/Green Positive and Black/Blue negative.
Jun 26, 2012 | 1998 Land Rover Discovery
Tip
Wire connections for RAB250D w\casset radio
Here is the electrical wire connections for the Clarion RAB250D w\casset in dash radio by color code. Yellow w\fuse holder is battery + constant source needed to retain progamming memory. Black is ground - negitive chassis. Red is the ignition key on + switch source. The speaker connections you should note that they are paired colors. The black trace is the - negitive on the speaker polarity. The solid color is the + positive of the speaker polarity. Purple set is the right rear speaker. The Grey set is the right front speaker. The Green set is the left rear speaker. The white set is the left front speaker. There is one blue wire with a white trace which is a power output to a optional power amp. Isolate this wire if not in use. Cap the end or tape it.
on Apr 30, 2009 | Clarion RAB250D
Wiring after market spekers need to know if a or b is positive or negitive
dont know about a or b but wiring should be color coded. these should be the colors and description for 02 silverado
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 31, 2011 | 2002 Chevrolet Silverado 1500
I cant remember how to hook up the speakers to the system
Speakers use a cable that consist of 2 insulated wires. The two wires are identified by one or more ways: 1) one wire may be golden colored and the other white or silver colored, 2) the insulation on one of the wires may have a raised ridge, or 3) the insulation on one wire may have some marking along the surface where the other will not
The terminals on speakers and terminals for the speakers on the amplifier will both have a (-) and (+) symbol for each cable (one for each wire). I like to assign the (+) terminal to the golden colored wire or the insulation with the rib or marking on it, and the (-) terminal to the white or silver colored wire or on the smooth or unmarked insulation. It does not matter which wire you assign to which terminal - as long as the (+) and (-) terminals of the speaker connects to the (+) and (-) terminals on the speakers of the amplifier (you should see to it that they do not get crossed so that the (+) of the speaker is connected to (-) terminal for the speakers on the amplifier).
Connect each speaker location to the corresponding speaker terminal on the amplifier (the front right speaker to connect to the front right speaker terminals on the amplifier - continue until all speakers are connected). Failure to connect correctly will make fading front to back and balance left and right work unexpectedly.
I hope this helps and good luck! Please rate my reply. Thank you.
Apr 09, 2011 | Audio Players & Recorders
What wires need to be hooked up to the positive wire and which ones for negitive
Red = positive to battery
Black = negative/ground to body
solid colored wires - positive speaker
while lined wires = negative speaker
Yellow = starter switch
Jun 06, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I want to change my front speakers on my 1999 Pontiac grand prix and i need the color code for the positive and negative wires. my car does not have the Bose system. Thanks.
cut the wireharnis clip that goes on the stock speakers off the wire with black strip is the negative the other is the positive or just test it by touching the bare wire to the positive and negitive on the new speakers it only works 1 way
Sep 11, 2009 | 1999 Pontiac Grand Prix
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
Don't know which is the positive and negitive wires
To be honest, it really doesn't matter - the speaker is just a resistor electrically, which is not a polarized component. You can hook either wire up to either side and you will get the same sound. In any pair of speaker wires, do you have one with a stripe and one without? If so, the striped wire is the negative wire. If you have a light colored wire and a dark colored wire, usually the darker one is ground (ie, yellow wire and purple wire in a pair for example - the purple would be the negative and the yellow would be the positive). But honestly it doesn't really matter which one goes to which terminal - electrically they have no real difference. If you hook them up "backwards" from what the factory intends, when the speaker plays, it'll pulse inward rather than outward from its mounting frame. It'll move the same distance with the same velocity however, so it'll create the same sound.
Sep 27, 2008 | 1994 Ford Club XLT
NEED TO KNOW WHICH IS POSITIVE AND NEGITIVE ON THE SPEAKER WIRES
on spearker wires on the head unit you will have 2 colors of each the ones with the black lines are negitive (example green...green with black line hope that helps
Jun 29, 2008 | Car Audio & Video
Pioneer TS-TRX50 Car Speaker Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
