Question about JVC HD-52FA97 HDTV
HAS SOUND VIDEO INTERMITTEN - JVC HD-52FA97 HDTV
  • vonnehka Mar 21, 2011
    REPLACE LAMP YEAR AGO.HAS SOUND VIDEO INTEMITTEN LOOKING AT pc BROAD SRA1024A.
  • vonnehka Mar 22, 2011
    I have raster when video goes out I dont have menu deplay I eyeball pc broad SRA1024A.but i have sound
  • JVC Master
  • 19,396 Answers
Hi.
At user level, the only thing you can do is ensuring that the problem is not given by a defective video cable or by a connected device. The TV is more likely faulty, and must be disassembled and repaired by a technician.
There are different parts to be tested. If you get intermittent picture , and TV does not go to forced standby (protect mode).
Test using different connected devices (eg. tuner and external DVD or console). IF problem is only with one device, then it may depend on the device.
If the problem occurrs using internal DVD or VCR, then the problem is the internal player.
Do a test by opening a menu on TV, and see if the loss of video affects the on screen display. If the on screen display stays there, then problem is digital video (main digital board), terminal board or circuits (inputs), or if connected straight to antenna, tuner board.
More commonly the loss of raster include the OSD, and you get a completely dark screen.
In that case most common failures are power board and drive power board supplying the lamp (often called ballast).
Testing is done monitoring voltage to the lamp while problem happens and testing voltage line from power board to lamp. The PSU supplies lamp on 12V DC line.
The full service manual have been uploaded here:Click here to start download..
If that does not work use this (same upload):http://www.mediafire.com/?t51c8y8ead3xka3
Regards.
Ginko.
Posted on Mar 21, 2011
  • Ginko
    Ginko Mar 22, 2011
    Hi.
    See if you can enter service mode, as described in page 36 of service manual.
  • 4,889 Answers
These are tell-tale signs of a failing lamp. Eventually you will end up with a no picture but sound problem and the lamp LED at the front blinking. Replace the lamp to resolve the problem
  • eagle338
    eagle338 Mar 21, 2011
    There is no rule that the lamp should not die in 1 year's time. Remove the back cover and check the status of the lamp when the picture goes out. Let me know what you found. We will also test the lamp driver to confirm whether its the source of the problem
I have a timing problem. Low idle speed that is intermitten and causes a stumble at starts. This problem also occurres during normal running RPM's. Missing electronic signal but intermitten?
Could be bad sensor whether crank sensor, sam sensor, idle air control sensor, bad ignition module, bad coil or even timing belt. if you have a service engine soon light/creck engine light it's more than likely a sensor. If no light, probably timing belt/fuel filter plugged/ or weak fuel pump.
Jan 17, 2013 | 1995 Toyota Camry
Microwave made a small popping sound and shut off. Now display says "Door" whenever we try to use it and nothing happens. Do we need to call a repairman again, this is the third failure in 7...
yes the popping sound wad the intermitten door closer sparking it will not work because its not reading the door as been closed advisable to but new mw
Nov 29, 2010 | Microwave Ovens
I get a sqeeking sound when i engage the clutch and accelerate in 1st,2nd,3rd gear getting more intermitten and less often as i gear up and it gets more intermitten as i decelerate through the 3 bottom...
I had a similar problem on my 05. it turned out that one of the clamps which tighten the exhaust coming from the catalytic converter.muffler on the bottom of the bike had a bolt which was completely gone. I put another one in and torqued it down and the squeaking stopped,
Sep 18, 2010 | 2004 kawasaki VN 1500 Vulcan Classic
My hd52g886 has intermitten picture with sound
when the picture is out see if you can see the lamp light on in the back inside the tv. if its still on you might have a problem with the optical engine. if not try replacing the lamp part# tscl110u
Mar 27, 2010 | JVC HD-52G886 52" Rear Projection HDTV
32pw6515 32'' philips crt no sound or intermitten sound
if the jack out side works okay, that indicates that the pre amp is fine. the sound on the pre amp is tapped before the main amplifier.
check the main amplifier ic in side if it is getting hot.
you need to charge that ic.
okay
Oct 24, 2009 | Philips 32PW6506 32" TV
Toshiba s1800 intermitten screen fault
problem with the video card can occur this...try reinstalling the video driver...but there can also be hardware problem....
Sep 05, 2008 | Computers & Internet
Phillips hdtv 30 inch
if you can bring up a menu and change sources to alternate signal and video is present then tv is fine but if you are unable to bring up menu and no video from any source then problem is most likely going to be with the small signal board
Aug 17, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Intermitten sound on my lc 37D7U
The problem was not with the TV, but with the cable box.
Jun 30, 2008 | Sharp Televison & Video
JVC HD-52FA97 HDTV Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
