Question about Samsung DV219AG Dryer
Good Afternoon Modle DV219AG Gas Dryer: The dryer will not start. We push the start botton the drum does not turn. After about 3 seconds I hear a click. (electric circuit type click sound) All of the lights and dials work as normal. Door switch seems to be working, when I open the door while it is still activated the door code show. The drum can be spun by hand and feels as it normally does when spun by hand. Thank you Benson
  • Samsung Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 21, 2011
When start button pushed, motor tries to start turn, won't turn, shuts off after about 5 seconds. It's a whirlpool modle LGR7646eqo gas dryer, several years old.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Apr 19, 2011 | Whirlpool LGR7646E Dryer
My samsung gas dryer model DV219AG won't spin & dry after make the settings & hitting the start button.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 06, 2010 | Samsung DV219AG Dryer
When I take the drum out and unhook the belt the motor will turn otherwise when I push the start botton I hear a whine like motor wants to turn
Your motor is weak and will not start under load... replace the motor...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 15, 2010 | Dryers
LG Gas Dryer (dlg0452w) needs a push to get going
heatman101
Apr 19, 2010 | LG DLG0452W Gas Dryer
The dryer will not run its cycle, the drum does not turn nor does the fan run. However, the timer counts down as though it is running a load. Door is tightly closed and temperature in room is not below 32...
I have a g e dryer modle # dblr333eeocc when i hit the start botton the dryer just hums. If i spin the drum by hand and then hit the door switch the dryer will work untill you open the door
Feb 17, 2010 | Bosch Axxis WTA 3510 Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
The drum won't spin.
It sounds like the belt tensioner is bad. To look and see it the front panel must be removed for inspection. The belt wraps completely around the dryers drum with the belt running through a belt tensioner at the botton. The bearing and roller assembly should be checked thoroughly to see if its worn bad
Feb 06, 2010 | Amana ALG331RAW Gas Dryer
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Samsung DV219AG Dryer Logo
204 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
