Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
I have a scotsman ice maker model# CSW45 when i first turned it on it made ice but very thin and uneven thickness then the next time i turned it on it made no ice. everthing as far as i no is working fine. I can feel cold temps on the freeze plate but not cold as it shoud be. Thank for any help.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Uneven ice usually water dispersment prob. or low freon charge, metering device not metering charge evenly.
Posted on Apr 18, 2012
2 Suggested Answers
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
SCOTSMAN ICEMAKER ICE SLAB NOT DROPPING DOWN TOO GRID
WHEN WAS THE LAST TIME THE EVAPORATOR WAS DESCALED? WHEN IT GOES INTO HARVSET DOES THE EVAP PLATE THAW OUT OR STAYS FROZEN?
Jan 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
I have a CSX45A1D Scotsman under the counter ice maker. Need manual for this unit. Thanks Dennis
Hi I think your model is the csw45 if it is then you can download the manual from http://www.scotsman-ice.com/docs/uploaded/sct/manual/Csw45m.pdf
Jul 29, 2011 | Scotsman CSW451D 15" Ice Maker with 26 lb....
Why does my scotsman ice machine, model cm250ae-1e, freeze over on ice cube grid?
check ice thickness thermistor if its not working properly timer will never start advancing
Jan 19, 2011 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 05, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
134 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
