In error I deleted the printer when trying to stop the prints from coming out of the printer. I re added it and re started the computer and it stated "new hardware detected" however it still will not print.
I am completing the project and need to print ASAP.
All-in-one printers like yours have a BUNCH of drivers that need to be installed. That's why it has such a lengthy install program. Sometimes you just have to start from scratch. So let's back pedal and try it again. You're going to need the CD that came with the printer.
First:
Click Start
Click Control Panel
Click Printers
If your printer shows up here, remove it
Then:
Disconnect the Printer cable.
Run the Install program again
Only plug in the cable when prompted to do so
When you plug the cable in it should now recognize the printer.
one day it works-all of a sudden today it doesn't work. says the cartridges aren't aligned. won't...
(More)
one day it works-all of a sudden today it doesn't work. says the cartridges aren't aligned. won't realign. I've tried turning it off and on, resetting to default settings, took the cartridges out and put them back in. It has always worked fine. I have tried to find new drivers for it-they all say they are free, then when it gets to the download, there is a charge for it.
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple...
(More)
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple of days ago. Test pages print fine from the print controller.
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has...
(More)
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has never been used for scanning
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
