Question about Dishwashers
The dishwasher will not drain. - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 21, 2011
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
When I start my dishwasher it start to run then it stop and flashes se code what causes that
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My portable GE dishwasher is clogged and wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Dishwasher is not draining
Hi
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
