Question about Dryers
Dg8200 maytag dryer not heating. whats wrong?
  • 10,865 Answers
Hello thirteen.... this gas dryer has a few possible reasons why there is no heat.
First of all, if you use propane, you may be out of gas.
Also, the gas ignitor may not be working or it may be dirty.
Call your gas provider. They will send out a technician free of charge to check your dryer and generally get it going once again. Joe
Posted on Mar 21, 2011
2 Suggested Answers
  • 713 Answers
SOURCE: Maytag dryer model DG8200 heats
CHECK FUSE IN DRYER.
Posted on Feb 15, 2011
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
My maytag will not heat up, what should I do.
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Maytag PYE2300AY Electric Dryer
I am using a Maytag Atlantis MDG7400AWW gas dryer. It is not heating. I have replaced both solenoids that open/ close the gas valves. The heat coil glows orange, and the thermal fuse is showing 0.0 when...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My Maytag Gas Dryer runs and starts to heat, but cools off. It takes a long time to dry. Model #MDG2600BWW What could be wrong?
heatman101./,,./
Jul 22, 2011 | Maytag MDG2600BWW Gas Dryer
My Maytag dryer Model MDG5500AW is running but the inside is cool and does not heat up. I tried both Sensor Dry and Time Dry, it still cannot het up. What could go wrong? And what do you suggest that i...
heatman101
May 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Neptune and it will not heat up. What could be wrong?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 09, 2011 | Maytag Dryers
My maytag MD-1 dryer will heat at times but latley has not heated, had tech check the heating element and it was okay, it was working okay when he left , but now want heat,what to check? the dryer is 4...
heatman101
Dec 28, 2010 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer will not heat up.
The most common cause for "No Heat" on GAS dryers is bad gas valve coils. Go here for more: Dryer Repair Help
Go here for Maytag Dryer Part Info: http://www.repairclinic.com/Maytag-Dryer-Parts
www.RepairClinic.com
Feb 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
Marvin
Marvin
