Question about Toshiba 32CV100U 32 in. TV/DVD Combo
Hello, I recently purchased the Toshiba 32CV100U (HD TV/DVD combo). The DVD picture is fantastic, but I am really struggling with the HD. When I watch a sporting event, the picture gets blurry whenever there is significant movement/action. When things slowdown, picture is fine. It is as if the TV does not have the power to process the picture fast enough. Very frustrating. Any thoughts?
    Top Expert:
  • Toshiba Master
  • 40,304 Answers
Inadequate design to capture rapid movement. The specs will show that.
Posted on Aug 07, 2017
  • 52 Answers
SOURCE: picture is blurry on new Toshiba 42HL67 lcd tv
Hi suegy, the quickest thing to test is play a dvd and observe the quality of the display. if still blurry or dull, could mean something wrong with your TV. going through what causing it...could be weak signal or CCFL lamp not glowing enough or fully.
Since its only a month ago, should be still u/warranty. Check out where you bought from and avail that warranty.
Good Luck.
Posted on Mar 01, 2008
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Posted on Apr 30, 2009
  • 11361 Answers
SOURCE: I bought at Toshiba HD TV/DVD combo 26
White screen means that the T-CON is nothing getting the 12vdc from the logic main board or the fuse on the T-CON board has blown. But first place to check will always be the power supply module first. Not sure about the clicking sound, DVD section?
Service manual:
Please see my basic troubleshooting guide here:
Posted on Jun 25, 2010
SOURCE: Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Posted on Jul 12, 2010
  • 11361 Answers
SOURCE: We have lost the sound on on Toshiba TV/DVD combo.
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Posted on Jul 27, 2010
Testimonial: "All good suggestions! "
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Codes for uneversal hd toshiba dvd combo tv
A universal is not likely to work for a combo unit---best bet is to Google the model number of the set and try to get an Original remote for it.
Jun 06, 2012 | GE 24991 Universal 3-Device Remote
Three month old Toshiba 19"
call here for tech support
  • Televisions & other consumer electronics: (800) 631-3811 (toll-free)
May 05, 2011 | Toshiba 19CV100U 19 in HDTV LCD TVDVD...
I just bought a Toshiba 32CV100U and i am trying to use it as a laptop extended monitor/speakers. I am running an audio cable from my laptop headphone jack to the hdmi/PC jack in the tv yet no sound comes...
You may have to check the on screen HDMI audio setup, it may be set to get the digital audio through the HDMI cable instead of the picking up the analog audio through analog port.
Both source and receiver of the HDMI audio setting must be setup correctly.
Please check that.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Instuctions connecting ps3 to hd ready tv
The answer is simple really. You can't connect your PS3 to your TV with a USB cable. You need an HDMI cable.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Screen turning blue now and then on various channels
Picture tube issue. How long have you had it? Call the manufactor.
Jan 03, 2008 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Toshiba 32CV100U 32 in. TV/DVD Combo Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
