Question about Garmin Nuvi 660 GPS Receiver
I have a Garmin nuvi 660 that has a non-responsive touch screen. I have held the power button until it brought me to the touch calibration screen. Once there I see the two lines which meet in the lower left hand side of the screen and meet to form a dot. I have pressed the dot with my finger and with a "stylus" pen and neither method has made the screen change or acknowledge that it has been touched. Any help would be appreciated.
    President:
  • 1,623 Answers
Has it occured that your touchscreen itself is malfunctioning
Posted on Mar 21, 2011
  • Martin Murray Mar 21, 2011
    you can buy a new one from herehttp://tinyurl.com/6bghy9g they are quite easy to replace only requiring the cable to be soldered back on to the unit.
    this is a quote from a poster to a forum i frequent
    I have just come across of a rather curious problem in a Nuvi 660 and a Nuvi 680 that landed into my lap with perfectly intact yet completely unresponsive touchscreens. A quick swap of good LCD/touchscreen packs into the said Nuvis proved that the problem was indeed in the touchscreens themselves.
    Upon a closer examination I realised that both units had some goofy aftermarket touchscreens installed. Although the pinout to all four conductive bars followed that of the OEM Nuvi touchscreens, the tracks themselves were cracked at the point where the Mylar ribbon cable met the glass plate. Of course this was hidden from the naked eye, but was quite visible under the Nikon microscope of my resoldering station. IMO these cracks represent nothing else but a flawed manufacturing process.
    Some of you might want to make a note of the tell tale signs of those sub par aftermarket screens for future reference.
    1. Unlike the black tracks of the OEM Garmin touchscreens the conductive tracks in the Mylar flex cable of these aftermarket digitisers are bright gold.
    2. Unlike the stamped on the Mylar ribbon part number "XA302A01" of the OEM Garmin touchscreens the flex cables of these aftermarket digitisers are devoid of any markings. However there is an inscription "002 STR-G50A AD3" in the left bottom corner of the glass plate itself.
    So it is worth replacing the touchscreen to at least see if it is the problem, which in my opinion it is
My Garmin 660 Nuvi touch screen will not respond I have put in the latest update, held the start button down untill the touch dot calibration shows and tryed the reset button none of this has worked, no...
This is a common problem due to certain style of touchscreen that is known to fail due to temperature. if you can not recalibrate the screen, then the touchscreen needs to be replaced. More information, including the recalibration procedure can be found here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jan 18, 2011 | Garmin Nuvi 660 GPS Receiver
Screen on my Garmin Nuvi 650 is frozen (no reaction to touch). Cna move through screens via the on/off button. Haven't updated maps...ever. Seems like most repairs will cost me $25 just in shipping. ...
The problem with the gps device is a minor one. First you ensure it is properly charged, then you reset it by holding down the power button for about 15 seconds, then it will restart and you will be able to touch the screen once again. If that does not work, then you need to calibrate the screen, take note that calibrating the screen does not just work the moment you try it, you need to try it repeatedly till you get it right. This is how to calibrate your nuvi:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Dec 28, 2010 | Garmin Nuvi 660 GPS Receiver
Hi! The touch screen on my Garmin nuvi 660 is not working. On boot up I can't get past the reminder to update map data screen. I have updated the unit software and tried to recalibrate the screen. As is...
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, screen calibration do not just work once you do it, you have to do it over time for it to work. Ensure you are calibrating properly. These are the proper steps to follow when trying to calibrate the screen:
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
Try this repeatedly till you get it to work. If it does not work, then it means there is an internal problem that need to be checked by a repairman.That should do the job for you.
hope this helps.
Dec 26, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Garmin nuvi 660 touch screen froze? How to fix?
please see this link. read about non-responsive touchscreens.
- Jim
May 12, 2010 | Garmin Nuvi 660 GPS Receiver
My touchscreen lost it's calibration and I can't recalibrate it
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Jan 20, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
146 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
