Question about Panasonic Televison & Video
Holographic image or double image especially when red colors are showing.
    Sergeant:
    Champion:
  • 234 Answers
Convergance/Focus needs to be adjusted. Consult your user manual on how to do this.
Posted on Mar 21, 2011
What are the advantages of holographic sight?
The biggest advantage of Holographic Sight over red dot is that prevents parallax distortion.
That is if your eyes are not properly aligned with sights in a red dot sight you will not hit what you are aiming with your sight, as you will not be looking parallel to the barrel of the weapon. This problem increases with the range of the target.
Holographic Sights, however, uses laser to produce a holographic reticle, which is not very prone to parallax errors.
However, there must be something which keeps Red dot in demand.
May 31, 2018 | Optics
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red color on top
Sounds like you need your convergence amplifiers replaced. Approx. $200-$300 depending on repair shop,
Jul 08, 2009 | Samsung HCM5525W 55" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
How do i center the colors, red, blue and green?
Replace Both of your convergence ICs STKs, big black ICs.
STK392-560, also CK pico fuses around ics you may have 1or2 bad .
HAPPY NEW YEAR!
Jan 01, 2009 | Sony KP-61HS10 61" Rear Projection...
Image double
convergence issues. i see this alot at the shop. i first suggest you read the article i wrote on the fl231 problem in my profile under tips and tricks. this might be a simple inexpensive repair. if this dont apply or help let me know and i see what i can do
Aug 16, 2008 | RCA R52WH73 Projection Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
