Question about Troy Garden
I have a Troybilt weedeater that works great until I put the tiller attachment on. With the tiller on, it dies after a few minutes of use. Any ideas?
  • 10,865 Answers
Hello dane. Change the fuel filter, install a new spark plug and a new air filter. Then get a can of carburator cleaner to add to your fuel. let that treated fuel run for 5 minutes and you should have your problem solved. If not, you will have to replace the carburator or rebuild it.
Joe
Thanks for choosing Fixya!
Posted on Mar 21, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troybilt 2840 snowblower runs 5 or 10 minutes than dies
fuel tank not venting and the float levels falls to low
Nov 06, 2017 | Motorcycles
Craftsman mini tiller runs great for a few minutes then revs up a little and then dies. Restarts after a few minutes and then repeats over and over.
Fuel starvation, try slacken the filler cap to rule out a blocked tank vent, if no better replace the fuel filter in the tank, if no better you will have ti remove the carb and clean the filer under the pump diaphram.
May 13, 2012 | Craftsman Gas Mini - Tiller/Edger
WE have rebuilt the carb and the tiller still runs for a few minutes then runs out of gas. We have put a new bulb primer, and we have new gas lines.
You definitely did good buy cleaning the carburetor and replacing the primer bulb. It is always a good idea to do that every 2 or 3 years.
But it sounds like it is probably a bad Ignition Module. Once the coil gets hot, it will stop working. You said it will run for a few minutes. How many minutes does it run before dieing?
Jim
Aug 05, 2011 | Ryobi Garden
How to attach hiller/furrower to troybilt horse tiller
how do you attach a furrower to a troy-bilt "horse" tiller
Apr 14, 2010 | Troy-Bilt Pony Garden Tiller
Engine manual for troybilt tb 144 mini tiller
Below are a few links that might prove useful. The first two are operators, and shop manuals for the 144. I briefly looked through them and they have engine related info. The third is just an exploded view of the engine.
Hope this helps.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb144_1.html
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/4cycle.html
http://www.partstree.com/parts/?lc=troy_bilt&mn=21AA144R966+TB144+Cultivator+%282006%29&dn=769021900001
Sep 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Mower won't stay running
brad, if it runs for a bit and dies it has to be a fuel problem. i would take the carburetor off and clean it real good with carburetor cleaner. go ahead and put a rebuild kit in it. they are fairly cheap. check the fuel lines that they are not dry and cracked. blow out the fuel filter or replace. blow out the fuel tank make sure it is flowing correctly. some have screens in the bottom that plug up. the 2 wire thing on the bottom of the bowl is a fuel shut off valve. if the key is turned off it will push up on the needle stopping the flow of fuel. a anti back fire valve. gently pull up on the black piece you will see sticking up in the bowl. if it comes off easily it will need replaced or cut off. it may be coming off while running causing it to run out of fuel and die. after it sets for a second it looses its suction and falls back in position letting fuel back in the carburetor so it will run for a few more minutes . dont pry it or pull it off just be sure it is not loose.
Apr 04, 2017 | Troy-Bilt Pony Garden Tiller
Parts list for Kohler K161T engine was mounted on a Troybilt Horse - older model. Need stator number - would like to see parts list or internet site to access it. Kohler has no spark
I have a troybilt tiller with a K161T Kohler 7 horsepowe engine. I have replaced all electrical components, spark plug, points, condenser, stater, all wiring, and cleaned magnets, but to no avail. I still have no spark. The points open and close properly, the plug is gapped correctly. Does anyone have an idea?
Apr 05, 2009 | Garden
Garden Logo
75 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
