Question about Cub Cadet Street Sign- tractor lawn riding mower parts
GT2542 mower (pre-2008 model). Steering very difficult. Attempted to lube at two points-one near the pinion and one below the battery. The pinion did well, but the other grease fitting stripped off when attempting to grease the segment gear assembly. I couldn't get any grease into it when it was attached. The assembly doesn't move by hand. I removed the c-pin in an attempt to separate the assembly from the cast iron plate which has 4 bolts securing it to the frame. I have tried to gently tap the spindle from the top and gently pry from the bottom. It won't budge. Used penetrating oil. I removed the 4 bolts from the iron plate to try and separate, only to break one (used penetrating oil here too). How can I get this thing off?
  • 109 Answers
SOURCE: hydro gear hand release valve doesnot alow you to
Check to make sure the brakes are not engaged
Posted on May 03, 2009
SOURCE: I HAVE A CUB CADET GT2542 RIDING MOWER. I CHANGED
There is no way to reset it. It will stay on until the hour meter reaches 102 hours and then the light will go out
Posted on Jun 13, 2009
SOURCE: Bought my Cub Cadet 18M from Home Depot in
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I was ‘gifted’ with a non-working Cub Cadet 18M mower a few weeks (July 09) ago by a neighbor. The mower was purchased in the Summer of 2007 and exhibited the same problem as yours (started briefly and then died) in late 2008 and was then abandoned in the weather until it was given to me.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The carburetor is held against the ‘intake’ side of the cylinder head by two threaded studs via a gasket, a stamped sheet-metal heat shield (approximately 3.5 x 5.75 inches), a short black plastic manifold, and another gasket. The heat shield tends to vibrate in resonance with the engine vibration; this vibration eroded the gasket between the heat shield and the carburetor mounting flange to allow ambient air to enter into the gas/air flow into the intake side of the engine. This extra air “leaned-out” the gas/air mixture causing the engine to die.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I disassembled the components and removed and discarded the heat shield and its gasket and made a new gasket out of oil-wetted index-card stock. The machine now starts on the first pull and runs well.
Posted on Aug 04, 2009
  • 11 Answers
SOURCE: Mower stolen.
$249.00 or try home depot.com
Posted on Aug 11, 2009
2strokeJim
  • 577 Answers
SOURCE: I understand what you are saying about burning oil
Did you overfill the crankcase, sounds to me like the problem, did it do this before you changed the oil ?
Posted on Oct 10, 2011
How to take play out of rack & pinion steering
New pinion gear! - some are adjustable - to push the gears closer together - but I doubt it on a lawn mower
= new rack - Sorry
Apr 24, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Pinion gear jumps the sector gear when trying to turn left. Right side fine.
no model number but some have a plastic fitting that hold the shaft down into the main gear it has a bolt that goes threw it into the bottom of the steering shaft about a $15 part but again no model number to see the set up
Jun 10, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Pontiac G5. Steering wheel spins freely, wheels don't turn. Is this a U joint issue?
either the steering shaft has broke or the rack and pinion is broke have someone turn the wheel and look under hood near where the steering shaft meets the rack and pinion. do you see it spinning? if so the rack is most likely broke inside. if not the steering shaft may have snapped. hope this helps
Jan 31, 2011 | 2008 Pontiac G5
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Rack and pinion steering is rough and creaking
ive never seen one that is rough,,but the I shaft,probably need lube and adjustment,there is a TSB on it for clunking and noisy,,,if it got less than 36000 take it to dealer they will fix for free
Oct 08, 2009 | 2008 Saturn Aura
Steering Problem
Only lube points you might have are on the ball joints and outer tie rod ends. Many come "sealed" and have no provision for service, others will have zirk fittings or a small nut in them that needs to be removed and replaced with a fitting. Your power steering should also be checked to make sure that it's operating properly.
Jun 26, 2009 | 1993 Geo Metro
Power steering fluid leak
check the lines to the rack and pinion,,,,cpild have a ruptured line
Nov 16, 2008 | 2004 Jeep Liberty
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
135 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
