The player was working and then it just quit no picture or sound
  • robmur1955 Mar 21, 2011
    i just wanted to know if something could be reset or if a fuse could have blown
    Top Expert:
  • Audio Player... Master
  • 79,865 Answers
One of two things has happened here, either the motor that spins the disk has failed or the laser has burned out or the power supply is burned out for the laser. Based on the current prices of players it is not cost effective to repair them, the most cost efficient thing to do is just replace it
Posted on Mar 21, 2011
  • yadayada
    yadayada Mar 22, 2011
    To reset just unplug for 5 minutes, as far as a fuse there are only fusible links and if they go then a component is shorted in the player, more than likely the motor or laser light driver circuit.
  • 10,319 Answers
The output in the circuitry has gone bad causing this problem
generally most electronic repair shops will give you a free estimate to repair
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
Portable dvd player dropped now has sound and faint picture
I usually prefer to fix things but here unless this is a very expensive unit let it go, it did enough damage to cause image issues and a screen hinge broken, if it can be repaired it will always be prone to some collateral issues that may show up later, like a small car in a accident, no matter how good the repair place is it will never be quite the same.
Dec 19, 2012 | Accurian 16-680 Portable DVD Player
I am getting sound from the DVD but no picture. I
I've fought with this for a while and finally figured it out. I recall another piece of hardware that would perform some sort of auto reset when it was unplugged so I tried it and it worked! I don't mean just hitting the power button, I mean crawling down on your hands and knees to follow the power cord from the back of the dvd player to the wall/power strip. Unplug it, wait a few seconds and plug it back in. BAM! All fixed.
-Kevin
J-ville
Dec 27, 2010 | Sony DVP-NC85H Multi-disc DVD Player
Car cd player ..................no sound
check shorted speakers or they are getting old and need replacing
Apr 22, 2010 | Kenwood KDC-MP5032 - Car Audio CD MP3...
My 120gb ipod suddenly quit working.
It sounds like the hard drive has faulted. You could try a Reset. if that doesn't work. you need to have it serviced, i suspect, a replacement HDD.
Mar 29, 2010 | Audio Players & Recorders
My screen quit showing pictures sound works is it a fuse?
my sceen will not show pictures everything works but the pictures from the dvd
Oct 11, 2009 | Audiovox MVDVD4 Car Video Player
Unit quits after 10 minutes/ screen black and static- noaudio files on card
I call this a problem with a capcitor inside the unit has leaked or has bulged.. Witch is not provding the power it needs to function properly see www.badcaps.com just for a example what are bad capcitors.
May 24, 2009 | Astar PD-3015 Portable DVD Player
My DVD player quit working. It was plugged into my Yamaha amp. I hooked up another dvd player, I get sound and no picture. When the dvd player is connected directly into the TV there is picture & sound. I...
Try using the composite video or SVHS video outputs on the original DVD player with the Yamaha amp. The other DVD player might have a switch on the back to select composite or component video outputs.
Dec 13, 2008 | Audio Players & Recorders
DVD Player turns on spins says reading but there is no picture or sound.
I had same problem and once left the player on for 3 weeks (left for vacation) and it still never worked. Finally had to dissassemble body of player to get dvd out. There appears to be no solution to this problem. I have called it quits and this cheap piece of junk is now in the trash. Koss will never be on my list of best buys.
Feb 27, 2007 | Koss KS2503 System
14 people viewed this question
 Grubhead
Grubhead
