My machine is pumping water out the dispenser door what could be wrong
  • 101 Answers
If you mean that water is coming out via the drawer that you put the powder then:
The powder has become solid in the drawer and blocked off the pipe leading to the drum.
What you need to do is to get boiling water and pour it into the detergant and using the pointy end of a wooden spoon break the sludge free in the pipe and the detergant draw.
Please leave feedback
Posted on Aug 02, 2008
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Dispenser door
If the dispenser door is opening, then it is working properly. You have some kind of problem during the wash causing the soap to not wash out of thye dispenser. Either the pump is clogged or not pumping for some reason, there is not enough water coming into the unit or it is draining for some reason, or the water is sudsing up for some reason, usually rinse aid leaking into the water.
Start a wash cycle and let it fill completely with water then open the door and see how much water is in the tub. It should be just under the heater.
If it is ok, let it wash a few minutes then check it again to see if there are a lot of suds. If so, there is usually a leak in the dispenser.
Post back and let me know what you find.
Thanks/Mike
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Have a AML 125 front loader which is flashing three lights at us: The lock light flashing very fast plus Rapid and 1200-600 lights flashing. When we power up and close the door it starts doing this and...
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nessisary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 13, 2010 | Ariston Technologies Washing Machines
My washing machine gets stuck when it is going to start the rinse cycle
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
8)Oversudsing: Wrong Detergent, too much detergen, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
10)Water heating error, hE, the termister/heater is out.
Your repair Manual with photos and tech data HERE
I will leave that on there for a while but it takes up broadband so print that manual out and keep it close to that washer.
Feb 10, 2010 | LG WM-2277HW Front Load Washer
I have a Kenmore front loader washing machine that won't spin or drain. What is wrong?
Feb 07, 2010 | Washing Machines
Kenmore Elite HE4 won't start
Top 10 front-load washer problems
2)Excessive vibration: noisy,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nesessary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
8)Over-sudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
The washing machine keeps blinking sud what does this mean? It won't finish the cycle.. it is a kenmore front loader HE 5t
Either you have too much of the correct detergent in there or the wrong detergent in there. Here are a few of the errors:
8)Oversudsing: Wrong Detergent, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. Remove detergent, retry
Feb 01, 2010 | Washing Machines
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Massive amount of suds coming out under the door.
Someone put the wrong detergent in this machine causing the suds problem. Manually fill the machine with COLD water. Set it to pump out. Refill with COLD water and pump out again. You may have to do this several times to clear the suds lock condition.
Use only COLD water as HOT water will cause more suds.
Aug 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Water flow out of the door water dispenser is low nothing seems to be wrong
you have a water valve that pumps water for the door. need to check pump and replace if needed . most of the time it is the problem the water valve.. you might have two pumps on this fridg so make sure you get the right water valve.. one is for door and one is for the ice maker
Aug 12, 2009 | Maytag MSD2660KES Stainless Steel Side by...
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
