Question about Garden
Stay Right pool heater problem. model SR400NA has a loud noise at start up. sounds like rocks inside.
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
For starters you will need to proceed carefully...the noise you hear is water beginning to boil within the heat exchanger. The pressure that results can cause the unit to rupture or worse, blow. DO NOT ALLOW THE HEATER TO OPERATE IN THIS CONDITION FOR MORE THAN A MOMENT OR TWO as you attempt to repair it.
Water boils in a heater due to low flow, allowing the water to get too hot as it passes thru, or a faulty part or parts within the unit. We'll start with parts:
The bypass valve inside the header may be the issue if it is stuck closed. You will also want to inspect the thermostatic control valve in the header (if one is present) and inspect the overall condition of the heat exchanger. It is likely aggressive water has damaged some or all of these parts causing the banging noise you hear.
Your manual might also be helpful... http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
If the heater checks out then flow is the likely cause. It is possible there is an issue with the pump and/or filter not getting enough flow thru the heater. Check the overall system flow. If it is reduced too low the water inside the heater gets too hot and begins to boil causing the noise you here. Speeding the flow back up will eliminate the issue. Check all the trap baskets and the filter for debris and clean up what you find; backwash a sand filter or clean a cartridge or DE unit. If your pressure gauge is broke replace it and check system pressure. If it is low again that is a sign of a flow problem. If flow is low and all these items check out open up the pump and inspect the impeller for clogged vanes or a blocked inlet eye.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Posted on Mar 21, 2011
My 9 year old Sta Rite SR400NA pool heater starts normally, but about 30 sec. after the burner fires, it makes a loud noise (ca-chunk) and shakes several times. At that point, I can hear the burner go out...
Your "bypass valve" is open and the water in your heater is boiling. Close the valve at least 1/2 way (or more) , which will force water through the heater and restore operation. The bypass valve is located on the pipe leaving the filter just past the first tee.
Oct 26, 2010 | Sta Rite SR400NA Max E Therm Pool Spa...
Blown Heater blower motor
you will have to replace the brain unit its shorted out
Jan 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Owners manaul for SR400NA
If you have not received an answer to this issue, you can find an Owner's Manual online at:
I hope this is helpful!
Jul 12, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pool filter making a loud noise
The sound you are hearing is most likely rust forming on the inside of the motor. It tends to happen when a pump seal starts to fail. Water travels up the spining shaft from behind the impeller into the motor. The high pitch is a direct result.
Solution. Replace the pump seal, and find a motor repair shop/ Pool pump repair shop to take a look at the motor. Have them check the brushes and bearings. Once clean of rust the motor should be quiet once again.
Jan 25, 2009 | Harmsco Pool and Spa Cartridge for Filter...
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
