Question about Kenmore 74889 / 74882 / 74884 Top Freezer Refrigerator
How do I change the light bulb? I twist and pull but nothing happens. I have a Kenmore 106.72864100.
  • Kenmore Master
  • 5,425 Answers
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Posted on Mar 21, 2011
HOW DO I REMOVE INTERIOR LIGHT FIXING TO REPLACE BULB?
Try twisting it. Even maybe push in and twist bulb.
Jul 04, 2017 | Refrigerators
How to change turn signal lights
REAR UNSCREW THE UNIT PULL IT OUT TWIST THE PART THAT HOLDS THE BULB HALF A TURN PULL IT OUT REMOVE BULB REPLACE WITH SAME NUMBER BULB.
FRONT BULB CHECK TO SEE IF YOU CAN ACCESS SIGNAL FROM BEHIND UNDER THE HOOD. IF NOT REMOVE THE LENS BY REMOVING THE SCREWS AND ACCESS THE LIGHT THAT WAY. PUSH THE LIGHT BULB AND TWIST IT IT WILL POP OUTBECAUSE IT IS SPRING LOADED. ALWAYS MAKE YOU SURE YOU CHECK THE NUMBER ON THE REPLACEMENT BULB TO AVOID HAVING TO DO THE JOB TWICE/
Mar 01, 2014 | 1996 Dodge Dakota
Getting the brake light off to change light bulb
Most brake light bulbs are accessed from trunk interior. open trunk and look for removeable panels that might have 'click' catches. These panels will be adjacent to the bulb location. Once bulb socket is exposed, find the appropriate bulb and twist the socket counterclockwise about 1/4 turn and bulb socket should pull free out to expose bare bulb. Bulb should also either pull straight from socket or twist 1/4 turn and pull free from socket. Replacement is simply the reverse,
Oct 09, 2013 | 2005 Peugeot 307 SW
How do i change my rear brake light
I believe the plastic cover has either screws or clips on both sides just pry easy under pressing inward.. slowly haste makes waste with these little things... good luck bulb should pull straight out of the socket after twisting it out of the cover
Mar 05, 2011 | 1991 Toyota Celica
HOW DO I CHANGE THE HEADLAMP BULB ON MY 07 AVALANCHE
there are two rods one on each side, silver in color or black, just twist and lift them right out. the light will then just come right out
Jul 31, 2010 | Chevrolet Avalanche Cars & Trucks
How to change the right end brake light of corolla 2006
These usually twist out counter clockwise. then the bulb either twists out, or just pulls straight out. Then just insert new bulb and socket back in. (counter clockwise).
Let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 20, 2010 | 2007 Toyota Corolla
How do I change the parking light bulb on my 2006 Kia Rio?
The parking light is accessed thru the trunk. Pull away carpet and pull the connector from bulb. (be carefull not to pull wires off connector.) The bulb should then twist off.
Oct 14, 2009 | 2002 Kia Rio
Unable to change 2009 sidelight bulb
On the sidelight, there is a Phillips screw which is hidden by the headlamp assembly. Remove headlight assembly and look for the Phillips screw. Once unscrewed, pull lens unit straight out and then you should be able to change bulb.
Aug 21, 2009 | 2002 Ford SVT Focus
How do i change the rear light bulbs on my bmw x3
Simple open the trunk look at where the back end of the light assembly will be there should be a twist handle on the plastic twist it and there you go switch out your bulbs... Same goes for the bulbs in order to replace them twist the plastic and you should be able to pull it out.. Nothin to it ...
Jul 13, 2009 | 1994 BMW 3 Series
Can you tell me how to go about changing the passenger side brake light out?
open trunk, remove liner, remove two screws holding the plastic housing, then twist and pull out bulb socket, then twist and pull out bulb and replace.
Jul 10, 2009 | 2004 Chevrolet Cavalier
Kenmore 74889 / 74882 / 74884 Top Freezer Refrigerator Logo
303 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
