Question about Asrock K10N78M Motherboard
Ethernet connection - Asrock K10N78M Motherboard
  • Asrock Master
  • 27,725 Answers
If you are trying to connect through a modem/router the driver it should have come with a disk provided by your ISP
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-
2112_4-91313.htm
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
Posted on Mar 21, 2011
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
How can router, cable modem & Vonage modem be connected
Connect the Cable Modem - > The Vonage
Then Connect the Vonage -> The Yellow or Green Slot of the router
Connect your computer -> The Grey slot in the router
Run the Setup
Dec 11, 2010 | Belkin (F5D7231-4) Wireless Router
There is no connection to the other pc
3 ethernet cables 1 ADSL modem and 1 hub is needed to network computers together.
1. connect telephone cable to modem and switch it on. 2. one end of an ethernet cable is connected to the modem . consider this master ethernet cable. connect the other end of this to the master hub port. 3.now connect pc and any hub port with another ethernet cable(ec) say ec1 4. likewise ec2 to another pc .
try this out to get net in both pc's
Jan 12, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Ethernet cable connection to PS3
maybe your ethernet cord might need to be replaced
Jan 11, 2010 | Sony PlayStation 3 40GB System
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
Oct 13, 2009 | Cisco 857 Router (CISCO857K9)
Can the modem's ethernet port connect to a video game console?
Most modems that have both usb & ethernet connectors are either/or, not both. I recommend using
the ethernet connection to your computer than the usb - the ethernet connection is faster & more
reliable. It also frees up your usb port for other use. If you want both your computer & game console on
the internet, then you need to buy a router which will allow you to share the modem.
Jul 08, 2009 | Computers & Internet
Ethernet
dear ashprabha,
you are saying that your motherboard doesn't have a on board Ethernet slot. now, if u want to connect to internet means
then you have to purchase and fix a PCI Ethernet card. so that you can connect to internet.
Sep 26, 2008 | Intel Motherboard
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Config DVMRe to PC
  1. Main Menu
  2. Communications
  3. Ethernet Settings
  4. Enable
  5. On your pc click start, run type in CMD, click OK
  6. at the prompt type in ipconfig, hit enter
  7. write down the ip address, subnet, etc.
  8. On pc open network connections
  9. create new connection
Jun 05, 2008 | Computers & Internet
Asrock K10N78M Motherboard Logo
148 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
