Question about Video Game Consoles & Games
Plugged my ps3 in at a friends house. when i went to plug in the tv connections, the power cord melted. now the console comes on for 1 second and off again. the fans blow then off, red lights flashing. Its a 60gb release date console so warranty done. How do i avoid 168.00 sony bill
  • 101 Answers
Hmm,
It seems that you might of recieved a surge in the ps3, I would risk opening your ps3 and look for any scorched components in the power supply section.
There are plently of videos on how to open one:
http://www.youtube.com/results?search_query=dismantling+ps3&search_type=&aq=0&oq=dismantling+ps
Cheers
Posted on Aug 02, 2008
I plugged my ps3 into my friends he tv and now just have a blank screen when i connect it back up to my old style tv???? Why... please help
Have you tried this?
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
If this doesn't work, it may need to be repaired. A good place to try is www.videogame911.com. They do really fast work and save all your data.
Jun 16, 2011 | Sony Playstation 3 (PS3) Console
I turn the ps3 on but the video doesn't appear. i checked the tv and cords and nothing was wrong with them.
Did you check that the AV cords are plugged in right? Red to Red, White to White, Yellow to Yellow? Are they properly connected in the back of the PS3 not loose connections? It could also be that the PS3 display settings are at a really high resolution for your T.V. Try reset the PS3 resolution settings back to factory settings by turning the PS3 off and then hold down the power button for 3-5 seconds and you will hear some beeps it will load your PS3 resolution at 480i. Should give you your screen back.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
I have a wireless router in my bedroom where the internet comes into my house. My sons got a PS3 and have hooked it up, it is now saying the ethernet cord in not connected. What is this and how do I fix...
Check that ethernet cord is plugged in correctly to router.Ethernet cord looks like a telephone cord.
must be in the lan port of router.
You need to have a ethernet cable going from the back of the ps3 to your router in 1 of the ports.
or ps3 needs a wireless adaptor to pick up the wirless signal from the router.
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 has no power
Well I think your house might have killed the PS3. I would recommend talking to an electrician about what happened.
You can try using a different TV and see what happens. However...
Unfortunately the PS3 is pretty much dead now. Hopefully its still under some kind of warranty or can still be returned (tell them it won't turn on). To replace the parts needed would require precise installment and should only be done by professionals.
Sorry for the death of the PS3.
Don't forget to rate :)
Apr 08, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Not connecting to tv
If you changed the video output settings when you connected to another tv then you will have to reset it.Switch the ps3 on and hold the power button until it has beeped three times(not including the first power on beep).This should open a menu,choose option 2,this will revert your system back to default settings.Hope this helps
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont come on
There may be a problem with your power lead. Check it is correctly plugged in...
Take out the power cord, wait 1 minute. Plug it back in... Wait 5-10 minutes. And try again (make sure that the HDMI/TV Cable is also correctly inserted)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Nothing will show
When powering on the ps3, hit the power button and hold it for 10 seconds the PS3 will beep. This resets the PS3 to display at standard resolution.
Mar 03, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
