I have a Pioneer VSX-515 6.1 system and I am trying to hook up my phono to it. I am not sure which input to use. Right now the only input I have is my CD player.
    President:
  • 2,992 Answers
Like many newer receivers, this model doesn't have a phono input. I guess manufacturers think nobody listens to vinyl today. You can still hook a turntable to one of the extra audio inputs on this unit, but you'll need a phono preamp. The output level from the turntable is too low to drive a "line level" input directly, and the preamp boosts and equalizes the signal so it will work properly. Radio Shack still carries a preamp; you can order online or find it in some of their stores. Many other sources are available online, and if you have a good stereo shop in your area they probably stock one. Plug the turntable to the preamp input, connect the preamp output to the receiver and that's it. You'll also need an AC outlet nearby as the preamp needs power.
Posted on Mar 21, 2011
  • Mike Mar 04, 2013
    Sad when they think that people don't use turntables anymore! I'll have to buy a preamp too,because I'm having the same problem...
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Pioneer turntable to Pioneer VSX 515 receiver
I'm not sure what you mean by "Wot", but I assume you mean that the receiver doesn't have a phono input, as most receivers now a days don't. You will need a phono preamp. Cost is under $25.00. It provides the amplification to be able to use any high level(CD, DVD, AUX, etc) input as well as the RIAA equalization you need to decode the record correctly. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 12, 2013 | Pioneer PL-990 Turntable
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
How to hook up a turntable to a pioneer vsx-1019
receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
May 02, 2011 | Audio Players & Recorders
I have a pioneer rec. vsx-515. I do not have the instructions how to hook up the main sub woofer that plugs into the wall
What model subwoofer would that be? The Pioneer manual would offer some guidance on ITS end of this partnership.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-515-K-Receivers-manual/id/386ag000/t/2/
Apr 20, 2011 | Pioneer Audio Players & Recorders
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
Mar 16, 2011 | Pioneer VSX-515 Receiver
Pioneer vsx-515 no sound from dvd player plugged into coax input.how do you check the coax cable?
Its just a wire covered with a shield. You can ohm it out with a multimeter.
Mar 22, 2010 | Pioneer VSX-515 Receiver
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
Jun 19, 2007 | Pioneer VSX-D711 Receiver
331 people viewed this question
 Grubhead
Grubhead
