Question about HP Compaq Presario V2000 Notebook
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
    President:
  • 739 Answers
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Posted on Mar 21, 2011
    Problem Solver:
  • 7 Answers
This laptop uses a 2.5' IDE (PATA) hard drive.
Source
Posted on Mar 22, 2011
    Novelist:
  • 107 Answers
Standard physical size of laptop hard drives is 2.5". You can determine if the hard is an IDE or SATA by looking at the connectors. A quick way to tell if a Hard Disk is IDE or SATA is to check the ports on the back. IDE drives have ports with many small metal pins while SATA drives have ports that look like small slots with no pins.
Can i put my compaq presario 2200 hard drive on another laptop..if so which one?
You should place the drive from the Presario 2200 in an 2.5" external enclosure or use a USB/SATA/IDE adapter. (If you want to use an external enclosure, you will need to check if your drive has a SATA or IDE connection and get the correct type.)
If you replace the drive in a working laptop with the non-working drive, you will probably get the same issue. The error suggests that the Presario can't find an OS on that drive. At best, you will see errors due to drivers and Windows seeing a new CPU and motherboard.
When you connect via a USB connection, you be able to attempt to find the files on the old drive. This will be slow (limited by the USB speed). If you had a desktop, you could get faster transfers. If there is a free 3.5" bay, you will need a 2.5" to 3.5" drive adapter. Then you would need some adapters for the IDE connection to the motherboard (if the old drive is IDE and the motherboard supports IDE). Make sure the drive is on the "Slave connection" of an IDE cable and set for Slave or Cable connect. There are IDE to SATA adapters or PCIe cards that will support adding drives if your motherboard can't accept more drives.
Good luck. I hope this helps.
Jan 09, 2013 | Compaq Computers & Internet
I want to install windows xp-2 in my laptop presario cq42 notebook, i have a proble with hard drive for sata disable. in this laptop the bios not show the sata disable feature. so i want to disable this...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Compaq Presario Notebook
I took out my hard drive in my Compaq Presario V2000 and I'm not sure what kind of enclosure to get..like is it an ISE or a SATA and does it need to be 2.5 or 3.5
Standard hard drives are 3.5 inch. there are 2 formats IDE and serial ATA. If youre not sure which one you have, take it to the store with you and they will help you find the right one.
Mar 21, 2011 | Computers & Internet
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
Is the hard drive IDE or SATA or what?
The hard drive interface for it is ATA/100 IDE/EIDE.
Oct 02, 2009 | HP Compaq Presario V2000 Notebook
Hard drive replacement
Hi there, I have an HP nx6110 and it had a WD 60GB 4200 rpm IDE, I bought a Seagate 80GB IDE Hdd and it worked fine. The only think you should be careful is to check if you need a SATA Hdd or IDE Hdd, but I think it's a SATA.
Apr 02, 2009 | Fujitsu Computers & Internet
Compaq Presario V2000 won't turn on
Ah yes, another illustration of the value of backing up often.
You didn't mention the name of the drive maker but you might get some response to an email asking if they make an adaptor that would allow you to access it via a cable if installed in another system.
I have made dozens of adaptors to resolve this knid of bottleneck. Uuuh, that wasn't an offer to make one, I'm retired and age has stolen too much of my steadiness for soldering and eyesight to see what I am doing.
Dec 31, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario C734TU
Enter BIOS Menu and look for Hard Disk SATA IDE setting of AHCI. Disable this by setting to Compatible mode.
XP does not support AHCI mode.
Please rate me if this works.
Aug 05, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario V2000 not recognizing HD
option1:-replace your ide/ata cable and see whether it works. check your power cable also.
option2:- update your bios. download lastest bios from your motherboard manufacturer's website.
Jun 19, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
543 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
