Question about RCA Televison & Video
I have a 1988 rca demensia.Will only auto program to channel 63.How do I get it to program more channels,up to 70 at least.
    President:
  • 2,992 Answers
You don't. The tuner was made when channels didn't go as high, so it just won't cover anything more. If you want more channels, you'll need to connect a device like a cable converter box or a VCR with a newer tuner and use that as your tuner.
Posted on Mar 21, 2011
RCA stb7766c auto scan stops at 70%
You may have to repeat the auto scan procedure a number of times until your RCA STB gets in the mood to do a complete scan. This is one of the annoying characteristics of STBs in general
Jul 11, 2013 | Televison & Video
How do i program the channels on my rca
search in the menu on the set if not using a box for "auto program" making sure there the set is set to cable or air---antenna, whichever you are using and then auto program.
Oct 30, 2012 | RCA Televison & Video
It wont auto program channels,i have to do manually and when i turn tv off it loses all channels again
The main system memory IC to your TV is faulty. It should be replaced. It is a very small IC, having 8 solder terminals, and can be located very near to the main system control IC.
Jul 04, 2012 | RCA TruFlat 27F520T 27" TV
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
SD TECH
Sep 23, 2011 | RCA F25254GY 25" TV
I have a panasonic pv 9451- is there a way to reset the auto programming for the channels? can i reset the vcr programmed information entirelyu and start anew?i think i programmed out channel 3 which is...
Should be able to use the remote to access the VCR menu, and setup the auto programming. If not automatically, then you'll have to do each channel manually. Just check all your options in the menu.
Usually all vcr's have the option of channel 3 or 4.
Apr 14, 2010 | Panasonic PV-9451 VHS VCR
I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Nov 09, 2009 | RCA F27252GY 27" TV
Can't get channels above 63 without tuner on cable
i got the same problem to. when i autoprogram it still doesnt do anything. cannot get channels lower than 51 like all the rest of the tvs in my house can. Somebody tell me what to do..
Mar 18, 2009 | Televison & Video
My rca won't pick up channels when doing a channel search.
It sounds like you need to auto program the chanels on your t.v. There should be an opition in your menu. If there is not something called auto program or channel manager it my be in your set-up menu. I hope this helps.
Jan 08, 2009 | Sony KP-57WS500 57" Rear Projection...
Re: tv unable to program channels
NO!!! you need to auto program the T.V go through the menu and find auto progeam its easy
Dec 26, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
