Question about Frigidaire Ovens
Coil on bottom inside frigidaire oven has severed. It glowed first now has separated
  • 1,229 Answers
You can usually go to your local hardware store and buy a replacement coil. I had to replace one about one year ago. It is simple. Ask the neighbor to install it for you! Thanks for asking .
Posted on Mar 21, 2011
I have a frigidaire gas oven Model Number FGF366ECC. The oven does not get hot.
9 times out of 10 the oven ignitor is the problem see if the ignitor glows when you turn the oven on it should be a bright yellow glow and not a dingy orange glow if it does not glow at all the ignitor could be burned out
Nov 18, 2010 | Frigidaire Ovens
OVEN WONT LITE. THE GLOW COUPLER GLOWS AND THE BROILER LITES
sounds like this is gas unit . if so replace the bake ( bottom ignitor ) as it is weak . and this should correct problem .. mm hope this helped ..
Jul 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
Feb 03, 2010 | Magic Chef 9122 Gas Single Oven
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven
open the oven door take the panel off the inside bottom. turn your oven on bake if you see a red glow coming from the ignitor coil and the oven burner is not lighting you need to have the ignitor coil replace. I don't know what make your oven is so this solutoun may or may not work.
Dec 21, 2007 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
