Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I HAVE REPLACED MY BULB OM MY KDF-50W655 AND MY TV IS WORKING AGAIN, BUT I HAVE TRYED TO RESET THE TIMMER TO THE BULB THRU NMY CONTROL....BUT CAN'T SEEM TO MAKE IT WORK...
I have installed the new lamp and the the led power light comes on green and than turns flashing red. What is the next step in this repair?
Posted on Jun 03, 2011
  • 10,594 Answers
Sony KDF-50WE655 does not require lamp timer hours reset, put new lamp, tight its screws and put lamp cover, tight its screw and put lower front panel back in its position and tight its thumb screws. Turn On tv and enjoy tv shows.
Thanks.
Posted on Mar 21, 2011
I replaced the lamp but after flashing green it flashes red wat do I do?
hi,
check the lamp inserted is correct or not. also check the lamp cover, is it properly closed or not.
if its ok, just reset ur tv and the try again.
Turn on the TV. While holding down the up arrow button on the remote control, press the
POWER button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
ok
Dec 22, 2010 | Sony (XL-2400) Projector Lamp for...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF - 50E2000 Projection TV Lost Brightness control after replaceing bulb
Let me know have you adjusted Lamp Replacement option in Menu > Settings in TV?
Oct 04, 2008 | Sony KDF-50E2000 50" HDTV
6times flashing red light on sony grand wega kdf-60xs955
you may have a defective tv.
the best recommendation is to file a complaint, record the entire time you turn the tv on and it goes out, and show it to the next person that comes to service the tv.
Circuit city has a complaint form that you can ask for.
I did this once for a guy that "tried to fix" this exact same KDF-60XS955.
hope this helps.
Jun 29, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
1,277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
