Question about Hydro Systems JENNIFER7248 Jennifer 7248 in White
Hi peter - Hydro Systems JENNIFER7248 Jennifer 7248 in White
  • 604 Answers
Hi, how did you know where i was? Peter
Posted on Mar 22, 2011
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
Ignition problem: I have a gas hot water system: RINNAI CORPORATION; MODEL:REU-2008W-A the panel display temperature as 40C, when open the tap, the temperature display dropped to 12C, and no...
This is an error code 12, not 12 degrees. You have a short on your low voltage side by the sounds of it.. First disconnect the controllers inside the heater. Turn of the power first, 2 screws top and bottom to take the frnot panel off. Follow the low voltage wires (not the power point ones) to the PCB on the ride side and disconnect them both. Panel back on, power on and try the heater again. If this fixes it you have a short circuit in the controller or the wires leading to it. If not the most likely short circuit is on the thermal fuse which loops around the heat exchanger. This will need an expert, Perth has plenty north and south of the river. Give Rinnai a ring first, they have some good staff in Perth who might help.
Dec 02, 2010 | Rinnai Water Heaters
Hi I am looking for just the solenoid portion
I doubt that you will be able to obtain one. Those sorts of parts just aren't available.
Nov 13, 2009 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Oct 13, 2009 | Water Heaters
Hi my vaillant vcw gb 242 e is leaking from the
what do you mean from the radiator TEMPATUTE adjusting control ( thermosatic rad /valve) if so jurt replace valve
Aug 31, 2009 | Water Heaters
Hi where can i find a manual for a worchester greenstar 24i junior boiler please
if you go on the worcester bosch web site and contact the service dept they should send one out to you or you may be able to download one from there.
Mar 27, 2009 | Water Heaters
INSTANT HOT WATER ISN'T HOT ENOUGH.
http://homeappliance.manualsonline.com/manuals/mfg/rinnai_corp/reuva3237ffu.html
http://www.houseneeds.com/shop/HeatingProducts/RoomHeaters/rinnai/rinnaimanuals.asp
Here are two links to get the manual for your unit. Since I don't have the model number for your unit, you can find this in one of the two links. If you have the manual, you will know if you are skipping a step or not. If you have done everything, then I would call Rinnai to find an authorized tech for your appliance. Hope this helps.
Mar 20, 2009 | Rinnai Digital Remote Water Heater Control...
Boiler shuts down after an hour or so irrespective of heat level
Why did it shut down?Hi tempture which would be the hi limit,or like of water?Is there still power to the boiler?
Mar 16, 2009 | Water Heaters
Sluggish gas value in tankless propane water heater
I don't think clean until you remove it.the clean it well and fine waterless lub.for it
Mar 10, 2009 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Hydro Systems JENNIFER7248 Jennifer 7248 in White Logo
54 people viewed this question
Top Hydro Systems Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Hydro Systems Water Heater Expert? Answer questions, earn points and help others
