Question about Dryers
Dryer wont turn on its 3 years old we have cleaned the vent and lint trap and still nothing we tried the breaker and nothing if it blue a fuse how do we know?
    Master:
  • 414 Answers
Without knowing the model, I would assume that the "One Time" limit has blown.
It is basically a thermal fuse. Some models require a matched set in which both limits
must be installed as a set. This often is done from the back of the machine. Unplug machine
after shutting off breaker, remove back panel for most units that have the lint
filter on top, and for others with the filter inside the door the limit is accessed by
sliding a putty knife between the top and front and press the two clips back and lift up
the lid. The model and serial number are inside the door to order the part. To test the
limits you can check them by unplugging the wires to them and using an Ohmmeter
(across the terminals)
they should read zero ohms or almost zero on a digital meter, for an analog meter the
needle should move towards the right. Note: on dryers with the lint filter inside the
door the internal ductwork may be blocked causing this problem to occur and will
need cleaning by removing the two screws and cleaning out the duct with a vacuum
and/ or duct brush. Hope this helps.
Posted on Mar 21, 2011
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
Dryer will not turn on. I have cleaned the lint trap and the vent hose and no when we set the setting and try to start the unit no success. I have light in the drum. Any suggestions? Is there a reset...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 18, 2010 | Whirlpool LGB6300 Gas Dryer
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
The dryer works but no heat.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
Dryer Problem
SHUT OFF THE BREAKER to the unit then open the panel (3 Screws) that is in between the washer and Dryer you will see your venting hose ther remove the flex vent pipe from the exh duct closes Turn back on the pwr and run a load in the dryer see if it drys ok if you wil need your vent to the outside cleaned out
Jan 23, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryers Logo
35 people viewed this question
Top Dryers Experts
