Question about Pool & Spa
I have a GLC-1P-COMBO - AutoControl, AquaStar Pool Control GL-235, Sensors & 1.5"/2" Motorized Valve Combo. Today I noticed the "sensor" light flashing, which means that the sensor cannot read the water temp and regulate the heat. What do I do? Also on the actual valve there is an on/off switch with a "1" setting on the left and a "2" setting on the right with the off in the center. Where should mine be, 1 or 2? and what does it do?
    Top Expert:
  • Pool & Spa Master
  • 7,361 Answers
When on pool off should point to spa pipe when on spa opposite numbers should be same but don't have to valve matters
Posted on Oct 30, 2017
  • 125 Answers
SOURCE: Operating instructions for Aqualink RS8 pool/spa combo panel?
Posted on Feb 26, 2009
  • 1050 Answers
SOURCE: 02 sensors not ready
The code P0420 indicates that the catalytic converter is not functioning efficiently. This could be because the cat is damaged or the engine is not running very well and the cat cannot keep up with the emissions. You should ensure that the spark plugs and ignition components are in top shape before replacing anything else. If a compression check reveals a low cylinder, you will not be able to prevent this code as even a new cat cannot keep up with a dead miss. If the state of tune and the compression is good, then you'll likely need a cat.
I've posted the drive cycle just so you know what to do when you have resolved the code.
  1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 122°F (50°C) and within 11°F (6°C) of the ambient air temperature at startup.
    Do not leave the key in prior to the cold start or the heated oxygen sensor diagnostic may not run.
  2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire, and - if closed loop is achieved- Fuel Trim.
  3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 55mph (88km/hr) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
  4. Hold Steady Speed. Hold a steady speed of 55mph (88km/hr) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
  5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 20 mph (32km/hr). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
  6. Accelerate. Accelerate at 3/4 throttle until 55-60mph (88-96 km/hr). This will perform the same diagnostics as in step 3.
  7. Hold Steady Speed. Hold a steady speed of 55mph (88km/hr) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
  8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Posted on May 14, 2009
  • 14036 Answers
SOURCE: Check Engine code P1409
clean the egr valve port on intake use piece of clothes rack clean the built up carbon on inside of port.
Posted on May 20, 2009
  • 128 Answers
SOURCE: I have a Compool lx220 control for my pool solar
Check the valve actuator toggle switch. It is 180 degrees out. If the toggle switch is in the up postion flip it down or vise versa.
Posted on Aug 30, 2009
  • 1986 Answers
SOURCE: toyota mr2 roadster 2001 engine light on code po141 oxygen sens
bank 1 will be whichever side cylinder 1 of your engine is and bank 2 will be the opposite side. It's named bank 1 and bank 2 so that no matter how the engine is laid out, bank 1 is always on the same side as cylinder 1. I cannot say whether the right hand or the left hand one will be bank 1 as I do not know where your cylinder 1 is. The garage should know
Posted on Sep 08, 2009
Why is my GL235 solar heater control panel not heating the pool. The heating light is on and the power light is on. What should we do.
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Nov 15, 2014 | Goldline Solar Pool Control Package Gl-235...
Set a program for pool mode on
go into set up then programming highlight the item you want to make a program for set on time and off time if you want it to run continuously start time 2:00am to 1:59am it will go off for 1 minute then start back up
Apr 13, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Valves do not actuate from panel but do with switch on valve
make sure valves are activated go into system set up go to jvas then assign in and out make sure you have a pool and spa combo bezel board
Aug 28, 2012 | Jandy Aqualink Rs4 One Touch Control...
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
Pool & Spa Logo
100 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
