Question about Enhance Technology ENP-2320, Enhance 200W TFX12V Power Supply w/ PFC (ENP2320) Power Supply
Where can I buy enhance power supply w/pfc model enp-2320 Please let me know......
    President:
  • 1,082 Answers
Http://www.google.com/#q=Enhance+200W+TFX12V&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=fp6GTf6NAo7sOfKZ0eoI&sqi=2&ved=0CDUQrQQ&biw=1004&bih=583&bav=on.2,or.r_gc.r_pw.&fp=52f01a95353e1206
This is a google search which produced many hits. Mostly 49 dollars, one 'refurbished' for 17.10ish
Just click on this link to bring up same list.
Posted on Mar 21, 2011
WHAT IS A REMOTE ON OFF
It is the green wire in general you must plug a wire between Greens a black wire to put the power on
It called "remote on/off" because on old AT the power wasn't plugged on by the motherboard but by a switch directly wired in the PSU
Dec 17, 2012 | Enhance Technology ENP-2320, Enhance 200W...
46RV535U 46 in. HDTV LCD TV where is the fuse
There are several fuses on the power supply board.
Usually the one that fails is not the main AC line fuse (which is close to the AC line input), but the PFC fuse located, you guessed it, next to the PFC regulator IC on the board.
When the PFC fuse is blown (measuring open) you also need to replace the PFC IC and possibly other components on the board. Most of the time the PFC is sufficient though.
Here's a link for repair service for the board:
http://www.coppelltvrepair.com/p/751/toshiba-46rv535u-power-supply-board-repair-service-for-dead-refusing-to-power-tv-or-faint-display-problem
Also search there for the TV model, we may have repair kits or exchange services available!
Hope this helps!
Jul 30, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Dear Guru my power supply of my computer with model enp-2120d doesnt work no power output so please gave me some idea or schematic diagram,thank you.
Do not try to fix this power supply. Better to replace with new or good used. I see many on ebay from 13.50 to 25.00. Also google that model for other options. Most likely fuse on the power supply has failed but if you bypass the fuse, with jumper wire or another fuse, will blow again. Probably capacitors. Good luck
Aug 28, 2011 | Enhance Technology ENP-2120D (ENP2120D)...
My computer did not start when i tryied to turn it on, so i pushed the red butten to the side at my power suply and tryied again ther was a loud bang from the powersuply and ther was smoke comming out from...
The only thing to do at this point is to replace the Power Supply with a KNOWN to be good, compatible unit, and see if the rest of the computer hardware components are okay.
Going by your information stated that the Power Supply is an Enhance ENP-2224B SMPS, (Switched-Mode Power Supply), it is a special shape.
If it wasn't for the Slim Micro-ATX computer case you have, you could use an easy to obtain ATX form factor Power Supply.
From a quick search though it looks like a replacement unit is affordable,
http://www.censuspc.com/Enhance-ENP-2224B-2G-240W-SATA-TFX12V-P4-Power-Supply-for-Slim-microATX-Desktop-Case-Serial-ATA-Ready-bulk-pack-SKU-ENP-2224B-2G-pr-3033.html
There is simply no way to tell if the motherboard, and/or Processor, and/or Ram Memory, and/or Harddrive, etc., is okay without having power.
Unless you transfer the components on the motherboard to another working motherboard.
[NOTE*
If your Power Supply has a rocker switch on the back that lets you use 120 volts, or 220 volts, make SURE it is set to the right voltage.
USA?
120 Volts
Europe?
220 Volts
Australia?
220 Volts
Japan?
100 Volts ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Enhance Technology ENP-2224B, Enhance 240W...
PLEASE I WANT TO BUY A POWER SUPPLY ENHANCE MODEL ENP- 2320
http://www.shopwiki.com/Shuttle-XPC-SN41G-power-supply
Mar 21, 2011 | Computers & Internet
No power. Fan does not turn. Changed power cable but still no power
Then your power supply is dead. You can purchase a new power supply relatively cheap. Give newegg.com a try.
Feb 01, 2011 | Enhance Technology ENP-2120H, Enhance 200W...
The enp-2320 will not turn on, any thing i can do? is there a fuse i can replace?
Welcome I want you to help does not exist DC voltage reading was 1.5 disappear
Sep 16, 2010 | Enhance Technology ENP-2320, Enhance 200W...
Enhance Technology ENP-2320, Enhance 200W TFX12V Power Supply w/ PFC (ENP2320) Power Supply Logo
380 people viewed this question
Top Enhance Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Enhance Technology Computer and Internet Expert? Answer questions, earn points and help others
