Question about Cameras
Sony DVCam model DSR PD 100A not loading tape and presenting code C: 31: 40......what does this mean....this code not in manual?....oh yeah small yellow triangle with a line under it is flashing?
  • Max G Schoenfeldt Mar 23, 2011
    this answer makes sense....thank you....Max
  • 10,594 Answers
C:31:40 is self diagnostic error code that indicates problem with Drum Motor (video head assembly) that is either stuck/ jammed for some reason or spins on very high speed and causing problem in Sony DSR-PD100A camcorder.
Qualified camera tech is required for visual check to solve the problem.
Hope this info will help, let me know if you have additional question.
Thanks.
Posted on Mar 21, 2011
C3210 error shows in sony dsr45 ap dvcam
C 3210 is means : LOAD direction loading motor timeout,
Main region how it happen are,
1.if there is moisture in ur TAPE or if ur tape had an slack tape during search And Video head is dirty.
Best is to clean head drum or disconnect the AC power cord.
After reconnecting it,
May 31, 2014 | Sony DSR-45 Mini DV VCR
Sony PD 170 error code c3211
hello,
well it seem your mechanic problem. i have similar problem and i solved it.
first see the mechanical work, when the tape is insert it, see the drum head, is the drum is spinning? if not mean your flex cable in the top of your head drum may damage. or try to reconnect it.
if the drum head is spinning its mean capstan doesn't work, your problem is in here. try to change your capstan part.
if there still problem, i can help you freely just email me at otto.engineering@hotmail.com
or you need manual service i can share with you
thanks
otto
Jan 24, 2013 | Sony Dvcam DSR-PD170 DV Digital Camcorder
DSR-1800A DVcam TAPE EJECT ERROR 21
This error means the reel position motor is not moving the reels either together for mini DV or appart for large tapes. Usually because the sliders or gears have run out of lubrication and have seized due to not being serviced periodically. Otherwise there may be a foreign object stuck in there like a torn label etc.
Try a different size cassette tape, it may be ok on large if you are trying small or vice-versa, because it is already in that position.
Jul 12, 2012 | Sony DSR-1800 DV/Mini DV VCR
Error 91-455 show in sony dsr-1800p dvcam get a service manualfor this model. pleas.
Error 91:455 i means: Communication error between servo main and servo sub microprocessors.Dose it take the tape in?if can tell me more.mail me in Pemring@gmail.com
Nov 26, 2010 | Sony DSR-1800 DV/Mini DV VCR
Sony pd 170 not releasing tape,it showing c:32:11error, any sugestion plz....
Loading motor is not functioning so that C:31:11 message flashing.Hope cassette is already in.If you can open camera right side cover unload with 3 volt supply at loading motor.It will work
Mar 18, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Hissing sound
you can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Jul 12, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Error on SONY DSR 1500AP
<div style="text-align:center; width:150px; font-family:Verdana, Arial, Helvetica, sans-serif; border: 4px solid #336699;"><div style="padding-top:5px; padding-bottom:5px; padding-left:7px; padding-right:7px;"><div style="font-weight:bold; font-size:12px; margin-bottom:5px;"><a href="http://www.adoos.in/post/6702295/broadcast_equipment_repairdsr_pd_170p">broadcast equipment repair,dsr pd 170p</a></div>
<a href="http://www.adoos.in/post/6702295/broadcast_equipment_repairdsr_pd_170p"><img src='http://img.adoosimg.com/7e53d6f9d826f017583632c34e442dcd-1-2.jpg' border=0 width="100" title='broadcast equipment repair,dsr pd 170p' alt='broadcast equipment repair,dsr pd 170p' ></a> <div style="font-size:10px;">SUPERB BROADCAST EQUIPMENTS & MAINTENANCE...</div>
<div style="font-size:10px;" align="right"> <a href="http://www.adoos.in">classifieds</a></div>
<div style="font-size:10px;" align="right"> <a href="http://www.adoos.co.uk/house-to-share">house to share</a></div>
<div style="font-size:10px;" align="right"> <a href="http://www.adoos.fr/labrador-a-vendre">labrador a vendre</a></div>
<div id="control" style="display:none">aaquierplnew</div>
</div>
</div>
u can check the cables from dr board to mother board as its a communication error.
Jun 11, 2008 | Sony Dvcam DSR-390P DV Digital Camcorder
Pd170 c31:98 error
The error C31:98 it means Mechanical position fault..here u have to check the adjustment of position and phase Gear
Dec 08, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
