Question about Ovens
I just want an instruction manual for an Excalibur food dehydrator 744t model # ED900.
I have a ge profile oven model starts pt 916 when i broil food the "locked" light flashes, i usually keep the oven door open so i can watch the food after about 5 min the locked light goes off
The only thing spring to mind Mary is that you somehow selected a cleaning cycle which superheats the oven and turns burnt on fat and grease to charcoal. The cleaning cycle never finished and the stove remembers it. The light is flashing to remind you. When the cleaning cycle is in progress, the door locks until it is finished.
Either remove the wall power plug or flip the breaker and leave it overnight. It _should_ erase it from the memory. Or you have to compete the cleaning cycle as per the instruction book.
Sep 05, 2016 | GE Ovens
Why does the grill knock off
Do you have some sort of timer on? Or is it the kind where it will turn off and you leave the food on it for a while longer? RTM. Read the manual, if you don't have it, google it, put in your make, model and manual and you should get a .pdf you can download and read.
Dec 11, 2014 | Ovens
Temperature controls
Ok, I need some information from your to answer this question correctly. 1. How long is your preheat time? Must allow 30 mins for the oven to heat and settle, failure to do this you will have temperature issues, usually burning food. This unit was designed to use both elements to preheat, so inserting food too early will burn your food. 2. What rack position did you select for the product you cooked? This is really important!!! I am a certified tech and I understand this issue you have, but information is key to answer this for you. Most people don't read the instruction manual and treat this oven as all the others on the market. As the ovens get more features, its important to learn how to operate as instructed to avoid these issue and have a great turn out of good food at the same time. Please get back to me if you would like more help. Thanks Gere
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 07, 2014 | Viking Ovens
Panasonic nn c784mf
Yes, leave the rollers and plate in there.
Mar 12, 2014 | Ovens
How to work my arrow oven
Try Googling (arrow)(model)(manual) without parens.
Jan 03, 2018 | Ovens
We have recently bought a Casera 28L Microwave/Convection Oven. the Instruction Manual refers to Oreheating but gives no instructions on the procedure to turn it on. Can you help us please? Ken &...
Hi Guys,
What model have you got? I have one that I have owned for well over a year now with absolutely no problems. In fact I would have to say for the $119 I paid for it, it has been the bargain of the century so far.
My model is CAS048 and to preheat it is very simple. You set the press the convection oven button to set the temp you want (i.e 180 deg) and push start. The oven will operate until it has warmed up at which time it will beep 3 times. Open the door and put your food in and set the time you wish it to cook and you are away!
P.S, mine will shut off automatically after a few minutes of reaching it's set temperature if I don't open the door and set the timer on it, so it pays to have your food ready or close to ready when you set it to preheat as it warms up quite fast.
Apr 07, 2011 | Ovens
I need an instruction manual for a red centre outdoor gas oven
Instructions Things You'll Need:
  • Power supply
  1. Press the "Clock" button, then the correct number buttons to set the desired time. Press "Clock" again to confirm.
  2. Press "Timer" to set the timer function. Choose the desired countdown time by pressing the number pads, then the "Start/Stop" button. Press "Timer," then "Reset" to cancel the timer.
  3. Press the number pads to select a cooking time. Press "Power" to use a power less than 100 percent using the number "9" for 90 percent of full power, "8" for 80 percent, "7" for 70 percent, and so forth. Press "Start" to begin cooking.
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. Enter the weight of the item, then touch "Start" to begin. Enter the food weight by pounds and ounces, using a "0" for a decimal. For instance, if the food weighs 1 pound, 2 ounces, enter "1," "0," "2," then "Start".
  5. Select "Speed Defrost" to defrost food quickly. Enter the desired cooking time and press "Start."
Dec 21, 2010 | Ovens
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
Ovens Logo
75 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
