Question about Raypak SpaPak Spa & Hot Tub Electric Heate...
I have a GLC-1P-COMBO - AutoControl, AquaStar Pool Control GL-235, Sensors & 1.5"/2" Motorized Valve Combo. Today I noticed the "sensor" light flashing, which means that the sensor cannot read the water temp and regulate the heat. What do I do? Also on the actual valve there is an on/off switch with a "1" setting on the left and a "2" setting on the right with the off in the center. Where should mine be, 1 or 2? and what does it do?
    Top Expert:
  • Raypak Master
  • 7,217 Answers
Replace temp sensor or check for cut wire
Posted on May 25, 2016
PartsCenter
  • 125 Answers
SOURCE: Operating instructions for Aqualink RS8 pool/spa combo panel?
AQUALINK GUIDE
Posted on Feb 26, 2009
  • 246 Answers
SOURCE: Pool heater shuts off itself before the set temp is reached
need new board control kit
Posted on Aug 25, 2009
ghost45
  • 1280 Answers
SOURCE: 2000 Hyundai Accent GL
label/placecard on/at the driver's door
Posted on Oct 04, 2009
  • 767 Answers
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.11c0d2e.jpg
Posted on Oct 25, 2010
adamh294
  • 310 Answers
SOURCE: Hello my Raypak Versa Heater sounds like its
When checking functionallity of this heater heres what we need to look at.
Your pool is 6660 gallons with a 55,000 btu pool heater.
Right off the bat I can tell you that this heater is meant for a spa or small pool only.
Depending on where you are located this heater will not even keep up with heating this water in cold temperatures. You should have a 100,000-150,000btu heater installed for this pool.
Since this is what is installed, here it goes.
Make sure there is adequate flow to the heater. All heaters have a recommended flow rate which is more more productive than one that is too fast or too slow. Ideal for this heater is 55-65 gallons per minute, so make sure that the pump is not clogged and flowing freely.
Also, if this is an old heater and hasnt been serviced in quite a while, then the heat exchanger is probably overdue for a cleaning. When the heat exchanger gets dirty, all that heat produced by the burners just gets vented instead of heating the water. a yearly service is highly recommended on these low efficiency heaters.
By the way, you have a 55,000 btu heater that was 81% efficient the day it was installed.
This means that the actually heating btu's is already down to 50000.
the efficiency of these units will go down 2% a year if serviced, and about 3-5% a year if not serviced.
Long story short, the heater is undersized, and probably also needs to be cleaned.
Posted on Nov 15, 2010
Why is my GL235 solar heater control panel not heating the pool. The heating light is on and the power light is on. What should we do.
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Nov 15, 2014 | Goldline Solar Pool Control Package Gl-235...
Set a program for pool mode on
go into set up then programming highlight the item you want to make a program for set on time and off time if you want it to run continuously start time 2:00am to 1:59am it will go off for 1 minute then start back up
Apr 13, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Valves do not actuate from panel but do with switch on valve
make sure valves are activated go into system set up go to jvas then assign in and out make sure you have a pool and spa combo bezel board
Aug 28, 2012 | Jandy Aqualink Rs4 One Touch Control...
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Wayne
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
Raypak SpaPak Spa & Hot Tub Electric  Heate... Logo
133 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
