Question about Arris SURFboard SB4200 Modem
Is it possible
Hi Ginko,
Just got a question, I know it is possible for computer 2 to get on the internet by dialling into computer 1 via phone to get on the internet through computer 1's DSL connection. I just cant remember how, do you have any idea how to do it? If im not mistaken you have to bridge the DSL and dial up modem somehow.
Thanks
  • Thomas Lim
    Thomas Lim Aug 03, 2008
    The computer 2 by the way is in another location. Im trying to set this up so that I can have the DSL setup at home and then when I do field work I can access my network as well as the internet through any phone line without having to signup to dial up or setup any internet connection at that location.
  • Thomas Lim
    Thomas Lim Aug 04, 2008
    yeah youre right looks like its gonna be too slow. oh well back to the drawing board
  • 19,396 Answers
Hi, yes it is possible but it is not a good solution. If you are using Windows XP try configuring network using network wizard to configure as "this computer connects to the internet through another computer".
This setting does not always work straight away as you usually have to set up firewall.
AWith this set up the computer connected to the modem will act as a proxy, repeating the signal on the other computer.
This solution will make navigation slower, force you to keep low firewall defences.
Best thing to do is buying a modem or modem router and build network using a router.
Posted on Aug 03, 2008
  • Ginko
    Ginko Aug 04, 2008
    Sorry, I did not see you where using hyperterminal, thought you were connecting by ethernet.
    If you use hyperterminal you need a management software to use one of the computer as a proxy, and the whole thing, if it work will be extremely slow when you try to access internet from remote computer at home.
    More than Hyperterminal you need to build a VPN between the two computers and set the remote one as proxy server.
I want to flash my nokia 3110c. hw can i do it in internet
Its not possible to do via internet - You need to have a UFS based flashing box and the relevant software to do the flashing,
Mar 11, 2011 | Nokia 3110 Cellular Phone
How to install third party java apps on my SAMSUNG GT5233A mobile phone??????????????? Is it really possible??? then, how??????????????
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
Feb 01, 2011 | Samsung Star GT-S5233 Cell Phone
How to deactivate fixed dialling
Hi
Fixed dialing is a network-based service which should not be active unless you specifically ask them for it, perhaps it has been activated on your account by mistake and another customer is wondering why it doesn't work for him.
You would have to get in touch with your network operator to deal with this.
However, it may be possible to activate/deactivate it through the phone if your network supports this option. But requires a Pin2 code that can ONLY be provided by your network
You can go to Contacts > Options > SIM Numbers > Fixed Dial Contacts > Options > deactivate fixed dialling > Enter Pin 2 code.
Otherwise, put your SIM card in another phone if possible to see if you get the fixed dial issue still. If yes, please contact your network for assistance.
Good luck.
Aug 31, 2010 | Nokia 6263 Cellular Phone
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature. tdijimmy@hotmail.com
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
Accesing internet through iphone using Broadband 3g using latop
Hi
This will not work if you iPhone is jailbroken .
You must have SSH already installed.
Before you begin, make sure your iPhone is connected with your 30pin USB to your computer(Computer must have connection to internet),
and that SSH is turned on, and make sure EDGE is turned on.
What you will need:
-- Proxy - ccproxy - http://www.youngzsoft.net/ccproxy/ccproxysetup.exe
-- Archive with all necessary internal iPhoneUSB - ðð°ñ€ð¾ð´
-- Net Framework 3.5 - Download details: .NET Framework 3.5
-- iTunes
1. Extract Archive to desktop.
2. Install ccproxy on your computer, then run it.
3. Double click, or execute, file 1_start_ssh_tunnel.cmd - it opens a tunnel between your phone and your computer (do not close the window, you can reduce, postpone or scale down). Remember the phone must be connected to a computer via usb.
This image has been resized. Click this bar to view the full image. The original image is sized 502x182 and weights 6KB.
4. Next set a proxy for EDGE on your phone.
execute winscp.cmd, navigate to folder / private / var / preferences / SystemConfiguration
You'll need to transfer the file preferences.plist to you computer, and edit, or paste over, the Proxy area.
<key>Proxies</key>
<dict>
<key>HTTPEnable</key>
<integer>1</integer>
<key>HTTPPort</key>
<integer>808</integer>
<key>HTTPProxy</key>
<string>127.0.0.1</string>
<key>HTTPProxyType</key>
<key>HTTPSEnable</key>
<key>HTTPSPort</key>
<key>HTTPSProxy</key>
<key>ProxyAutoConfigEnable</key>
<integer>0</integer>
</dict>
5. Once edited transter preferences.plist back to your iphone and overwrite the existing file.
6. Click the Options button in ccproxy, and click the "Advanced", then click the tab Networks, then untick with "disable external users" save and go back to main ccproxy window.
7. Execute file 1_start_ssh_tunnel.cmd - it opens a tunnel between your phone and your computer (do not close the window, you can reduce, postpone or scale down). The phone must be connected to a computer via usb.
8. Execute proxy_tunnel.cmd - opens port 808 on your phone. (do not close the window, you can reduce, postpone or scale down).
The Internet should now work!
To jailbreak your phone just go to this site it will be done in a miunite
http://www.appleiphonereview.com/iphone-tutorials/iphone-jailbreak/
Hope this helps and do let me know
Feb 11, 2009 | Apple iPhone Smartphone
Chinese n95 restart problem
HI rajat
Here are some steps lety me know if they were helpful
1.format ffs
2.fix the imei
3. Download flash file
4.Make flash back up
5. Reflash the phone
Jan 30, 2009 | Cell Phones
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Printer problem
I think I had a chat with you , here is trancription:
You are now in session with bazza1963
ginko says:
hi
ginko says:
are you there?
ginko says:
seems you need to re-install driver softwar for your printer, do you have printer disks? and which version of operative system are you using (Windows XP, Vista, etc)
ginko says:
I will try to find drivers for windows, give me some minute
ginko says:
Here is Driver download page for your printer, start downloading the one for for your system:
ginko says:
www.qms.com
ginko says:
Here is installation guide, same as the one provided with printer: ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/5430dl/ig54dl.pdf
ginko says:
ginko says:
download the above driver software.
ginko says:
is the same as the one distributed in disk coming with printer , if you have the disk you can use the disk
ginko says:
Once you downloaded software do the following:
ginko says:
1 disconnect printer from PC
ginko says:
2 expand and install downloaded software, alternatevely use the disk provided with the printer. Do this with printer disconnected.
ginko says:
3 when asked from installation, or after installation, connect the printer to your computer using the USB cable , not the network (ethernet) cable
ginko says:
4 the printer will be recognised in Windows, if it does not restart the PC
ginko says:
You must use an usb cable to use this printer as a local printer.
ginko says:
You may need a router to use the ethernet cable (one similar to thick phone cable) provided with the printer
ginko says:
therefore ensure you are using the right cable
ginko says:
here is an example of usb cable, sometimes it is not provided with the printer, have a look,. This is the right cable you need to use to connect this printer to local computer, the other one is for network www.amazon.co.uk-
ginko says:
check on www.amazon.co.uk how it looks like and ensure you are using the right one
ginko says:
let me know if you need further help, I am not receiving much feedback from you
ginko says:
Best regards
ginko says:
Also check under printers in vista that you have this printer installed and that it is the default print
I could not get any feedback from you , do not know if there was something wrong with chat software
regards
Mar 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Modem - dont know how to use it
activate the gprs in your phone get the dialling key
insert the cd into rom connect the phone to the laptop
via usb cable after installing phone as a modem in add new
modem menu use the dialling key to dial.if not phone me on
9829793957
Sep 22, 2007 | Sony Ericsson W800i Cellular Phone
Arris SURFboard SB4200 Modem Logo
157 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
