Question about Microwave Ovens
How do you unlock a Eurokera electric cooktop?
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
Gas rings will not light because of no electric spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Baumatic Microwave Ovens
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
My hotplate is locked. new house no info book no idea how to unlock it. its a franke glass electric cooktop
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Apr 02, 2011 | Microwave Ovens
Do you know what the average electric cooktop lifespan is? We have a Kenmore that is 9 years old and working fine. However, we are in the midst of a renovation and are wondering if it wouldn't be wise to...
The life span of the range depends on it's use or abuse.... Common issues are burners and the connections that the burner plugs into. These are not hard to change out.... There is nothing that can make the stove useless, if you keep after it. Newer units do a better job of retaining the heat within the unit, oven wise....Which is nice.
A gas range is certainly nicer, so they say. It is faster, but has one odd issue: if you boil water over, you can put out the flame and have raw gas running in. Most work this way, expensive units have thermal sensors that would turn off the gas flow in flame out condition....
My wife loves her gas range....
Mar 08, 2011 | Microwave Ovens
I don't know how to disconnect the electricity from the Jenn Air cooktop.
Check the outside breakers, usually at the meter.
--Best regards, --W/D--
Jan 24, 2011 | Microwave Ovens
Installing microwave
Usually it's 29-31 inches, but please reply back with your brand and model number so we can help you.
Aug 17, 2008 | Microwave Ovens
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
