Question about Whirlpool Washing Machines
Hi. My Whirlpool Duet Sport washer stopped mid-cycle and is flashing F-. I can't open the door. Help!
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Posted on Mar 21, 2011
My whirlpool duet sport washer just stops completely mid cycle and shuts down
If it has a safety switch that shuts the washer down when the lid is open, it could be going bad. It's a simple repair.
Jun 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport that stopped mid cycle and the door won't unlock
If you still have water in the tub it is likely a drain problem.
May 23, 2014 | Whirlpool Washing Machines
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code 02 F
pump is obstructed and needs to be cleaned. Look in this thread for how to clear a duet sport pump trap.
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
104 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
