Question about Garmin Rino 530hcx
Does anyone have a wiring diagram & pinout for the Garmin Rino 530hcx? I have a Helmet with 2 speakers, mic & 2 PTT. I also have the plug (2.5mm x 11mm) with 3 contacts. Nothing I've tried has worked.
  • 20 Answers
SOURCE: Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
Posted on Sep 21, 2007
marked
  • 6487 Answers
SOURCE: Garmin Rino 530 no output
This is problem sound part or chip of the unit, that may probably need a repair, by the way did you try updating the firmware of this unit probably updating the software will fix this problem..
Hope that helps...........
Posted on Aug 14, 2008
SOURCE: Garmin rino 530HCx freezes up
pull battery off to reset or hard boot cpu! Its a computer.
Posted on Oct 25, 2008
SOURCE: Garmin Rino 530 battery wont charge
I had this same problem with my Rino 530. I searched google with no luck. As I was on the phone with Garmin, I put side pressure on the adapter (that plugs into the clip, which clips to the battery) and the red light would stay on. They said I needed a new wall charger and clip. So in the mean time I wrapped electrical tape around the adapter to keep pressure on it. Charges great now. Hope this helps!
Posted on Nov 02, 2009
  • 367 Answers
SOURCE: can a garmin rino 530HCx
This GPS works word wide. Your main thing will be to update / buy additional maps for the locations / countries you want. You can find them here:https://buy.garmin.com/shop/shop.do?pID=8523&ra=true#onTheRoad Just click View additional maps for this product under Buy additional maps, scroll down and click the one for Australia. Or click here: https://buy.garmin.com/shop/shop.do?pID=36360&pvID=37662 They cost $149.99USD
Regards,
Chris
Posted on Sep 05, 2011
I have a vintage Hy Gain Hy Power microphgone, model 610, that I would like to connect to a Kenwood 440 SAT HF transceiver. Please tell me what to connect where on the Kenwood 440 SAT mike plug.
White is the MIC wire
Copper shield is GROUND
Black is usually PTT, otherwise use RED for PTT
vpaxi2bbtoaaaaaelftksuqmccaa==
The above drawing is the TS-440SAT mic connector pinout. The pin numbers should be visible on the MIC connector.
You can get the complete manual at www.mods.dk for free.
Sep 03, 2017 | Kenwood Radio Communications
Heil icm plug wiring diagram
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
Jan 03, 2014 | Heil Sound Audio Players & Recorders
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
Dec 21, 2011 | Garmin Rino 530HCx 2.1 in. Handheld GPS...
Mic plug wiring diagram for connex 3300
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
This is the stock mic wiring but why bother just order a RoadKing 56 it is already wired for your radio. I suggest Copper.com dont even consider a Skythumper it is cheaper but the quality is not there.
Nov 12, 2011 | Radio Communications
I have a Rhino 530hcx, the volume button is stuck...when the device powers on the device locks up....other than Garmin, where can I get this thing fixed?
I am not sure if you got this fixed but mine is doing something similiar except it is the button above the volume (aquire other users) I had to press the button repeatedly at different angles to get the button to unstick. I have had this happen a couple of times now and the whole unit freezes up. Poor design in my opinion as this unit has only seen the field 3 times.
Jun 20, 2010 | Garmin Rino 120 2-Way Radio
I have Garmin Rino 530HCx, when I turn it on a strange screen comes on(software version, ESN, ......)iT THEN WILL NOT GO TO ANY OTHER SCREENS.It also will not turn off(have to remove battery to turn off)
It seems that the contact of your ENTER/ROCKER key are stuck. Try cycling the button a few times with a few gentle jerks. Or, if you are ready to take the risk, open up and clean the contact yourself.
Jul 06, 2009 | Garmin Rino 530 GPS Receiver
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Oct 20, 2008 | Garmin Rino 530 GPS Receiver
If i want to talk to my passenger what do i do?
you will need the headset extension cord. push and hold the "int" button till a beep is heard then either ptt or vox
May 14, 2008 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
Ritron RTX-x50, 2 prong adapter to single Motorola connector
Contact Ritron at 800-872-1872, ask for the engineering department.
Dec 12, 2007 | Ritron /Jobcom Lapel /Jobcom JBS146D,...
Garmin Rino 530hcx Logo
323 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
