Question about Yamaha RXV367 Receiver
I can't get any video from my wii on the TV. Sound comes through but no video, I've tried using the wii A/V cables as well as some aftermarket component ones. hooked them up as shown in the RX-V367 manual. Any ideas? Thank
    Sergeant:
    Champion:
  • 342 Answers
Are you using HDMI output? if so then there might be an issue with the reciever itself but try hooking a standard a/v cable to the output of your reciever and see if the wii comes up on that screen, then we can go from there.
Posted on Mar 21, 2011
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
We have sound but no picture on our Wii
Connect a DVD player using red white and yellow to the TV if you get picture and sound, then reconnect the wii red, white, and yellow to the same input.
If only the wii does not show video you will need new red white, and yellow cables. I would try a friends red, white, and yellow cables first even to their TV where their wii is already working.
If new cables are not working you will need to contact Nintendo as there is an issue with your wii. You can't change the wii video to progressive without a component kit, and since you have yellow you obviously don't have a component cable for the wii.
May 15, 2010 | Nintendo Wii Console
When I turn the Wii on it makes no sound
Check to see if the audio cables from the Wii to the TV might have come loose or unplugged.
If you have a friend with a Wii, see if their cable connecting the Wii to the TV works. Your cable might have gone bad.
Jan 13, 2010 | Nintendo Wii Console
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Need to get sound for wii w/ sony bravia tv and sound system
There is usualy a 2nd channel for games like example - video 1 is video games but hear the tv, video 2 is videogames and hear Wii. Hope it helps
Nov 29, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Wii console to Philips HDTV Connection not working
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Jan 26, 2009 | Nintendo Wii Console
Wii light is on but the Wii won't function.
Try the Wii "RESET".
Here's how:
1. Unplug the Wii for at least 5 minutes.
2. Plug it back in.
Dec 28, 2008 | Nintendo Wii Console
No sound on wii. were does the sound come from on wii
Wii's sound comes from the tv that you plug it into. You need to plug the audio composite cables into the same place you did to get the video to play. there should be a set of three composite jacks for your cables to plug into. Yellow (video) White and Red (audio) make sure they are all in the input side not the output side. turn you tv up to the desired volume and turn it to the proper input channel and you should be all set.
Dec 05, 2008 | Nintendo Wii Console
Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
Aug 16, 2007 | Nintendo Wii Console
Yamaha RXV367 Receiver Logo
124 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
