My television was on as a blackout occurred and was not plugged into a surge protector. The television comes on but as I attempt to cycle through my channels there is no "dead air" or "white noise". Before this happened the television had no issues...
    Sergeant:
    Champion:
  • 342 Answers
The sound chips may be toasted from the power restoration surge because when the power is restored a surge of electricity will come through the lines that is why I do recommend a really decent surge protector.
Posted on Mar 21, 2011
    Sergeant:
    Champion:
  • 234 Answers
Needs a new tuner or video board. I am sure it will also need a new power board as well.
I have a motororola model MBP8 PU babby montior quick working after power went out they turn on but but don't work
Is it plugged into a surge protector? When the power comes back on to a lot of residents at the same time, a power voltage spike occurs that can damage electronics. All items that have any electronic circuits, need to be protected by a surge protector. Surge protectors do not protect against lightning strikes.
Jun 04, 2014 | Computers & Internet
Hey there! Just replaced the lamp in my sony KDF70xbr950 and now it will not even come on I have 4 flashing red lights and then goes back to a solid red light can some one help!! ...
The LAMP light is flashing or blinking.Solution
If the LAMP light is flashing, first attempt to perform a power reset on the television. If this does not resolve the issue, then the lamp inside the LCD projection television may have burned out and will need to be replaced. If this appears to be the case, consult the Replacement Lamp Part Number table to determine the correct replacement lamp for use with your projection television.
NOTE: The LAMP light is not the same as the POWER/STANDBY light.
How to perform a power reset on a Sony® television.Solution
Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds.Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.Turn on the television.
Sep 16, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blinking red light in front of tv (lamp) and noise coming from tv as well.
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2200. You can download the manual of the TV by clicking here. Refer to page # 76 of the manual for further information. Follow the steps below to perform a power reset first:
Try the following steps to check if the issue can be resolved.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony KDF-E55A20 55 in. LCD Television
Flashing Lamp light, no picture KDG42WE655
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2100U. You can download the manual of the TV by clicking here. Refer to page # 16 of the manual for further information. Follow the steps below to perform a power reset first:
Jul 16, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
Not coming on at all. lost it when rolling blackouts during freeze
most likely its a goner when rolling black outs occur you can bet on there being power surges so to prevent that from happening again you should always have all your important and sensitive equipment connected thru a surge protector and not a power strip or the wall protection and prevention save lots of headaches :) i hope this helps
Feb 07, 2011 | 2wire Computers & Internet
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Turn on tv and standby light flashes 6 times
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue.
Follow the steps below to perform a power reset:
  1. Turn off the television.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Oct 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
