Question about Everex StepNote NC1500 Notebook
I have a laptop and it runs so slow. The battery life is beyond horrible so I have to keep it plugged up at all times. I have not used this laptop alot until now because I am a college student. Its almost not even worth using:/ hellllllp!!!
  • 26 Answers
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Posted on Jun 16, 2011
Computer say its always charging even when not on charger
Based on the symptoms I would suspect a failed lithium battery. Most people think they should keep their lithium batteries at 100% but that actually shortens the life (number or recharges). I always suggest that you should try and let your laptop run down to 50% before recharging. Leaving a laptop constantly plugged in results in the same outcome - constant recharging of small amounts so you can see that the 'life cycle' is related to the number of times you recharge and if you are constantly doing it then you will most likely be shortening the battery's useful life. Unfortunatley most laptops will not run without the battery so the user's only option is to run their laptops on battery and not plugged in to AC until at least 50% dissapation thus optimizing the battery.
Just in case you have not done this, try removing and reseating the battery. Jarring of the laptop can somtines alter a good connection but from what you said it is unlikely.
Jul 07, 2014 | ASUS G73JHA1 Notebook
Tip
Battery life extension
All batteries lose their capacity to hold a charge over time, but how you take care of them can affect how quickly this occurs. To keep batteries better for longer, try to drain them nearly all the way before charging, and charge them fully every time. If you're not going to be using the battery for a while (a couple weeks or longer) drain it to about 80% before storing it. For laptops and other devices that often stay plugged in, fully drain and charge the battery about once a month. Doing these things can help slow down the degradation of the batteries in your gadgets.
on Mar 01, 2011 | Computers & Internet
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
Hp laptop plugged in and not charging
when plugged in does it say charging at all ? well you can have several issues, either the power supply is bad ( hp makes horrible power supplies and they fail all the time. ) battery could be bad ( not sure on age and usage amount on the laptop. or you may have a bad ac port on the laptop itself. the batteries can get a " memory " and most people do this by leaving it plugged in for hours on end while using, this is bad it strains the batteries while the unit is on and running, thus shortening the life span. but it will be one of the three. also try to remove and reinsert the battery pack, you may have some gunk build up on the contacts. if you do not want to take it to a shop, try battery replacement first , then narrow down.
Mar 12, 2014 | HEWLETT-PACKARD Computers & Internet
Not Charging problem
Your battery is dead. Batteries only have a useful life and have to be replaced. Your power cord is ok because you are allowed to be on the computer with it plugged in. But the power cord cannot charge a dead battery that is beyond it's useful life. Replace the battery.
May 25, 2012 | Computers & Internet
Laptop Toshiba A60 - Heats Up, goes off after running 20 minute
replace the battery . battery has its own life time and after that it needs to be replaced . so do it.
May 13, 2010 | Toshiba Satellite A60-S1561 Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Battery Life
your battery needs to be replaced...
Feb 24, 2009 | Acer TravelMate 4200 Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Nx 9010
Simply plug the ac adapter into the wall, the laptop will charge the battery itself.
Keep in mind this... in general, a laptop runs at full speed when it is plugged into the wall. When most laptops are running on battery, things are running more at 50% capacity to save on power, this giving you more battery life. A dimmer lcd and slowing the processor down when not needed are common traits.
You can use the FN key (function key) and the corresponding dim control on the keyboard to adjust the brightnedd of the backlight. It should be marked on your keyboard in a different color, like blue or maybe green (not familiar with that models keyboard).
Oct 21, 2007 | HP Compaq Business Notebook NX9010
Everex StepNote NC1500 Notebook Logo
226 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
