Question about Refrigerators
The freezer is working fine everything is still frozen but the fridge has stopped working meaning its not keeping the food cold, have turned up the dials but no change, The fridge light still works. HELP! Mena
  • mena66 Mar 21, 2011
    It is a freezer top/ fridge bottom have located a plastic box in fridge whiich has 2 dials on it one for the refridgerator compartment that goes from normal to coldest which I have set to coldest and a meat draw dial which has a vent and set to coldest. there is also a dial in front of the light that is set to 4
    I cannot feel any cold air but have opened and closed the door a couple of times since adjusting the dials just incase it showed a change.
    I located what you described even tested opening and closing the door but no change the freezer is still working, have also adjusted the temps as suggested????
    Genius:
  • 1,157 Answers
Hi mena66,
Just another thought on this concern, have you tried checking the damper? This problem sometimes happens when there's a damper issue. There are several ways on how to check this, either you check if there's enough room for air flow or locate and check the damper assembly. Here are some steps that you can apply on checking the damper assembly.
1. Remember your safety. Please wear gloves before attempting the repair.
2. Please locate the damper assembly. Every refrigerators have an electric damper that opens and closes when it's running. Make sure that the thermostat is turned on and the freezer fan is running.
--> Normally you can feel the air coming through the vent on the damper. So you need to check on it.
3. Hold the damper in the light switch or you can just tape it so the machine will thinks the door is closed. Some models will close the damper when the fridge door is open.
4. If after doing the step 3 and still don't feel any air, please remove the damper cover. Also check if the damper door is closed. If it is closed, please make sure that is is not froze shut.
5. Now manually open the door with your finger and ensure that it can move freely.
6. If it can move freely then you need to replace the damper. Most of the time damper would jam because of some foam or insulation falls on its path.
7. If you noticed the damper is open but can't feel air, kindly check your evaporator freezer fan.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 21, 2011
    President:
  • 2,468 Answers
Depending on whether its a top,bottom,or side x side refrigerator/freezer,look for the damper vent door near the left upper corner in the refrigerator on an upright freezer top,lower freezer near the center bottom of the refrigerator compartment,or in a side x side refrigerator its on the upper left side between the refrige and freezer section ,all damper vent doors are behind plastic grilles,and you should hear and feel cold air from there from the freezer section,if they are frozen shut from ice they cannot open,take a hand held hair dryer and defrost them then try and adjust temps in refrige and see if the door opens and closes with temp adjustments
Lg lbc22518ww bottom freezer not keeping food frozen
door seals may be bad. check for cold air leaking especially on the corners and the hinge side.
Feb 28, 2014 | LG LBC22518 Bottom Freezer Refrigerator
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Have a side by side fridge (think it's a Hotspot. The fridge part works fine (as long as the freezer is still running). But the Freezer part is no longer working. Was fine one morning and by that...
Look inside back of freezer and see if ice is forming or a layer of frost is building. If yes it is time to manually defrost and examine these parts=> PSS26MSRSS_Freezer_Section
After clicking on that link you will see photo's of your freezer section. In that photo part location's 230 and 240 are 230 Defrost Heater OEM Part Number=> WR51X10055 That part is most likely burned out. Once you defrost manually with a hair drier or a large bucket of hot water set inside the freezer compartment you may need to take care that water does not over fill the condensate
pan below refrigerator by mopping up the water with a dry towel.
Next part I always change is the=> WR50X10028 Defrost Thermostat
These parts are easy to see and change once the rear panel of your freezer is removed. In most cases you will see the defrost Heater blackened and burned out. Removal of the rear freezer panel is very easy and will save you a lot of money to do this yourself. Just remember to unplug power always while working around electricity and you will be fine. Should you have other questions I will be here to answer them for you, Thanks Sea Breeze
Jun 09, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer working well fridge not working at all
there is a fan in the back of the freezer that pushes air into the fridge side of the fridge it sounds like this has gone out on you. this fan is usually right by the coils in the freezer the only thing that keeps the fridge cold is a little air being pushed over there constantly
Apr 27, 2009 | Refrigerators
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
