Question about Alpine CDM-7833
When i shut my car off all the presets and the clock and settings reset! whats wrong?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
You need to make sure the yellow wire is going to a constant power source. that is, a source that is still hot when you turn the key off. the yellow wire controls your memory for your clock and preset stations.
Posted on Mar 21, 2011
Instructions for jensen jcr-425 clock radio, how to set clock
To preset a channel on the JCR-425, you tune in the channel; press the "AL/MEM" button on top of the radio (at which time you will probably be switched to some other radio frequency, which is rather disconcerting), press the "Up" or "Down" button to select the desired preset channel number, press "Set" -- and only then are you returned to your desired radio station. If you want to preset several channels,
You might then think that the next time you turn on the radio that all you would have to do is press one of the 10 preset channel buttons on the front of the radio to visit one of your preset radio stations. You would be wrong. You must turn on the radio, then press the "AL/MEM" button on top of the radio. Only then can you access your preset radio stations.
You might also think that to turn on the radio you would press a button that says "Power." Wrong. You press a button that says "Radio." Well, okay. But you might think that to turn it off, you would just press the "Radio" button again. Wrong. If you have pressed the "AL/MEM" button to access your preprogrammed channels, pressing the "Radio" button simply takes you out of the "AL/MEM" function and back to the "FM" (or "AM") function, apparently taking you back to the last radio station you tuned in manually. To turn off the radio after accessing a preset channel, you must press "Radio" twice.
Nov 06, 2016 | Jensen JCR-425 Clock Radio
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
Radio resets when car is turned off
There is a yellow wire in the harness coming out of the head unit, this should be connected to a constant power. This circut maintains power to the head unit for the clock and memory.
The red wire should be connected to a source that is turned on and off with the key switch.
Jun 01, 2010 | 2003 Ford Focus
How do you reset the clock on a 2007 Honda Accord?
Press and hold the SOUND button until you hear a beep. The displayed time begins to blink.
Press on the H (Preset 4) side of the bar until the numbers advance to the desired time.
Change the minutes by pressing the M (Preset 5) side of the bar until the numbers advance to the desired time.
When you are finished, press the SOUND button again to set the time.
You can quickly set the time to the nearest hour. Pressing and holding the SOUND button, then pressing the R (Preset 6) side of the bar sets the clock back to the previous hour.
If the displayed time is after the half hour, the clock sets the clock forward to the beginning of the next hour.
For example:
1:06 would RESET to 1:00.
1:52 would RESET to 2:00.
Hope this gets you there.
Dec 21, 2009 | 2007 Honda Accord Sedan
Clock is in military time mode. How do I reset to regular? Also I want to preset radio stations and I've lost my manual.
Here is your manual in PDF format:
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
To preset up to 6 AM and 6 FM stations - Use the Track/Tune buttons to find the desired station. Then, on the control panel only, hold down any Preset button until the preset number lights. The station is now preset to that number.
Dec 05, 2009 | Bose Wave Radio
How do u reset the time on a honda civic 2004
Press and hold the CLOCK button until you hear a beep. Change the hours by pressing the H (Preset 4) button until the numbers advance to the desired time. Change the minutes by press the M (Preset 5) button until the numbers advance to the desired time. When you are finished, press the CLOCK button.
Vehicles without CD Player
Adjust the hours by pressing and holding the CLOCK button, then pressing the H (Preset 4) button. Adjust the minutes by pressing and holding the CLOCK button, then pressing the M (Preset 5) button
You can quickly set the time to the nearest hour. If the displayed time is before the half hour, press and hold the CLOCK button until you hear a beep, then press the R (Preset 6) button to set the clock back to the previous hour. If the displayed time is after the half hour, the clock sets forward to the beginning of the next hour.
For example: 1:06 will reset to 1:00 or 1:52 will reset to 2:00
Oct 30, 2009 | Honda Civic Cars & Trucks
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
AV-S17 - Clock Display won't stay on?
Check the internal memory battery if there is one, then reset the sleep setting? Check the manual regarding memory back up.
Sonic Doctor
Mar 27, 2009 | Aiwa AV-S17 Receiver
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Memory/settings non functional
I'm not sure if car radios have internal batteries, but that's what keeps preset memory on home radios. In any case, preset memory requires a small continous electric current, and if there is none coming into the radio then when you switch the car off it will reset. Hope you find something along that line
Mar 15, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
Alpine CDM-7833 Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
