Question about Troy bilt Super Bronco Tiller 208cc
Not getting gas to my 6.0 bronco tiller - Troy bilt Super Bronco Tiller 208cc
    Problem Solver:
  • 15 Answers
I just solved this one. There is an orifice that controls the "run" fuel that is held in place by the idle adjustment screw. Remove the air cleaner. Remove he airbox mount plate held in place by two screws. Remove the choke control face plate that is held in place with two chrome cap nuts. This also secures the carburetor to the intake. Disconnect the fuel line. Disconnect the throttle shaft linkage and spring. Remove carb from intake studs. Remove the idle adjustment screw. Carefully pry the plastic orifice plug out of the carburetor body. Clean the orifice with a small torch tip cleaner. I used the smallest one in the set. I think it may be around .010 inch or so. While you have the carb off remove the bowl and clean the main jet and make sure the float and needle are clean and move freely. Reverse steps to assemble. I bet it starts first pull and runs choke off after minimal warm up.
Posted on Jun 19, 2013
    Master:
    Sergeant:
  • 411 Answers
Did you leave gas in it all winter with out stableizer in it Well you need to clean out your hole carberator or do you have a fuel shut off on this
Posted on Mar 21, 2011
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
Troy bilt troubleshooting tiller
sounds like not enough vacum to draw fuel .faulty diaphram pump. gas cap should have a breather assembly to allow air to enter gas tank and prevent a vacum lock as well
Jun 29, 2014 | Mtd Bronco Rear Tine Tiller
How do you get the belts off of the super bronco tiller
There is a tennsioner for the belt that you can loosen up to remove the belt. There is a screw that loosens up the belt tensioner.
Good luck.
Jul 27, 2011 | Troy bilt Super Bronco Tiller 208cc
Where can I get an owners manual for a troybilt bronco tiller? I think the tiller is 5/6 years old
You should ask the people you bought it from, but if you can't find them you can look around on the 'net to find other people with the same machine.
Nov 10, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Built Tiller - How much oil does it take?
About a quart ... but dont overfill. There is a dip stick on the engine.
Aug 03, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
What motor oil does the troy bilt bronco use
10w-30 should work.it should say what oil to use on it
May 27, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Troy-bilt bronco leaks gas from the air filter hopusing. How can i fix this?
Leaking gas through the air filter ports can only mean excessive gas flow from the carburator. Try adjusting the flow screws on the carburator bowl. Check all gaskets, seals, etc. and happy tilling!
May 06, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy bilt Super Bronco Tiller 208cc Logo
338 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
