Hi, I had my system set up on my TV, it worked perfectly until a thunder storm blew the power and since then it wont work, is there a fuse in the system anywhere? if not is there any way of getting the control to work, you plug it in and no lights come on on the volume control.
    Sergeant:
    Champion:
  • 234 Answers
Well there is a fuse. It is the whole tv. You will have to atleast replace the power board. I would also suggest a surge protector.
Posted on Mar 21, 2011
My Emerson lf46iem4 46 inch tv stopped working after a storm... What part would I replace to fix it?
IT COULD BE THE POWER SUPPLY GOT SHOT OR THE TUNER DEPENDING ON THE CONNECTION WHEN IT WAS IN USE .SOME TIMES THE TUNER GOT SHOT WHEN THE SET IS CONNECT WITH THE COAX CABLE LIGHTNING WILL SURGE THROUGH THE CABLE IF IT IS NOT GROUNDED PROPERLY ...GOOD LUCK
Oct 12, 2014 | Emerson Televison & Video
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
We had a thunder storm and the tv suddenly went off now i have no sound or picture, it was connected to virginmediia cable through v+box, no aerial involved, also the standby light doesnt even light up
If there's no LED light at the front panel, this is an indication that the power supply board is not working/dead (I'm assuming here that you had already tried to plug it to other working outlet). First part to check in this kind of symptoms is the internal fuse of the power supply board. It is where the power cord's directly connected. If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free) open the back cover, check the continuity of the fuse using the multimeter. If you found it open replace it with same current(ampere) ratings and then try to power on the TV. If the new fuse blew again, this is an indication of more serious problem on the power supply board.
Let me know the status of the fuse and the exact brand and model no. of your TV to assist you further.
Jdvillanueva
Sep 01, 2011 | LG Televison & Video
Not getting power to tv.Socket and plugs are getting power ,there was a thunder storm,but every thing else fine.
The problem of your tv is the power supply the thunder storm cause that. You should unplug your tv when not in use, try to check the fuse if busted, their are two classification of a busted fuse, if the fuse is only open try to replace it but if the fuse is all burned out dont just replace it, it has a shorted parts like the regulator and the bridge type rectifier
Jun 24, 2011 | Televison & Video
TV WORKED FINE AND AFTER A THUNDER STORM, WONT POWER ON
Sets such as this still have power applied to stand-by circuits whenever it is plugged in. Try unplugging it for 5 min or so and then if normal operation does not return, ask around for a competent repair shop. With lightning or surges it can be either something "simple" to someone experienced (about $50 maybe) or well exceeding replacement cost. A power strip with surge protection is a good idea in the future, unplugging everything is better but not always practical.
Sep 05, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
T.v. keeps blowing a fuse
The storm probaly blew your horizontal output or one of the Diodes in the brdge rectifier. Hows your soldering skills and what model set do you have?
Jan 21, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
